View Poll Results: Black top or colored top?
Black/Clear Top 22 45.83%
Matching Body Color Top 26 54.17%
Voters: 48. You may not vote on this poll
Old 02-03-2021   #31
Default Re: Black top or colored top?
Originally Posted by Bob Eyres View Post
My car had two tops when I bought it with 3Kmi. in 94'. But I'm a "coupe guy". I kept the white body color top and left the "see through" black one with the dealer for $500.00. That top has never been off the car in 27 years, except for cleaning and adjustment.
A see through top is a poor choice here in the Florida heat with the C4 ZR-1's feeble air conditioning. Too flexible also. JMHO.
I'm with you Bob. Both my ZR-1s had extra tops that I never used. They just sat in the basement. The '95 actually came with a transparent top that was an aftermarket replacement made of Lexan. It was crazed so I got a stock type from Melrose Tops. But it also sat and went with the car when I sold it. I think I put it on once just to see what it was like and concluded I didn't like it. So I stuck with the solid color tops. When I ordered my 2016 Z06 coupe I did not select the dual top option, got just the standard equipment body colored top. Rarely even take that off. Lesson learned. --Bob
Old 05-18-2022   #32
mlipmd
When I had my C5 I would change between the two depending on the seasons and heat, but it was way easier to do that by just loosening the clamps holding it on and it only took a minute or two. The C4 is a much more of a PIA with the 4 bolts that have to be individually removed, so my solid color top stays on, for now.
mlipmd is offline   Reply With Quote
Old 05-18-2022   #33
Subfixer
Subfixer's Avatar
When I'm ambitious, the transparent top goes on in spring and fall. Solid top in summer to help the AC stay cold.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 07-01-2022   #34
JT ZR-Won
Originally Posted by Subfixer View Post
Spring/Fall - transparent top (Blue tint). Summer - body color top (White).
That's what I do exactly
JT ZR-Won is offline   Reply With Quote
Old 07-06-2022   #35
tokuzumi
I would definitely like to source a body colored top for my 94 in competition yellow. It's nice to have the clear top in cooler weather, but in the 90+ degree days it gets a little hot.
tokuzumi is offline   Reply With Quote
Old 07-07-2022   #36
Karl
Karl's Avatar
You can install one of these which is static cling and removable or apply nano ceramic window tint.
https://www.ebay.com/itm/25341885875...fdae%7Ciid%3A1
Old 07-28-2022   #37
soslow
soslow's Avatar
Although I have both tops, I prefer the clear top without a doubt. I kind of get claustrophobic with the painted one on and feel too confined. My air conditioner works great and have no problem in the heat of the summer.
Sent from my iPad using ZR-1 Net Registry
soslow is offline   Reply With Quote
