Old 04-10-2019   #31
frantinoro
Default Re: 1990 ZR-1 Hesitation when full Power
So the system JUST threw a code 55, which it has never done before. Also at the risk of sounding stupid where is the second map sensor?
frantinoro is offline   Reply With Quote
Old 04-10-2019   #32
frantinoro
So is there a good way to test the coils or just 4 new? Plugs are new and wires ohmed good.
Old 04-10-2019   #33
Ccmano
Ccmano's Avatar
MAP sensors are at the back of the plenum, likely the one you are aware of, and under the ECM Mount. Code 55 is a “Fuel lean” code which could coincide with either a vacuum leak, fuel supply issue or both.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 04-10-2019   #34
Ccmano
Ccmano's Avatar
If the coils are original I would replace them, they are almost 30 yrs old.
H
Old 04-10-2019   #35
frantinoro
Coils were supposedly replaced by the PO and look relatively new.
Old 04-10-2019   #36
frantinoro
I still probably order new wires and coils to be safe as 4th gear low speed bucks quite a lot
Old 04-10-2019   #37
Ccmano
Ccmano's Avatar
Do you have a Factory Shop Manual? Diagnostics for code 55 can be found on pages 6E3-A-78 and 79.
H
Old 04-10-2019   #38
frantinoro
I do not yet. I'll check eBay or something later tonight and probably order one. In the meantime do you think you could PM me the one page?
Old 04-10-2019   #39
Ccmano
Ccmano's Avatar
Here you go...
Old 04-10-2019   #40
frantinoro
Okay, I'll test it later when I am out of school. One thing I did notice is my car would stay in closed loop - I assumed it would go into open loop once warm, no?
edit: i see I had it backwards. I will do this test tomororw! Thank you for the picture.
