Old 10-19-2018   #31
Karl
Karl's Avatar
Default Re: Aluminum flywheel.... new clutch?
Looks like the dual friction is the same dimensions, just stronger.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 10-19-2018   #32
zr1assassin
zr1assassin's Avatar
I wonder if it would match up just fine....
zr1assassin is offline   Reply With Quote
Old 10-19-2018   #33
Vette73
Originally Posted by Ccmano View Post
Yup, sprung hub disc helps with the rattle. Some transmissions rattle very little, some like crazy. Higher idle speed at 850 helps too. Had buzz saw sound on the old trans and engine. New trans and engine don’t have it. In my opinion it’s the Valley drain tube vibrating. I would isolate the tube with a rubber hose over it so it can’t hit the block. Or, just remove it altogether. If the secondary drain hole has been drilled per the service infomantion bulletin it superfluous anyway.
H
Have to get mine up in the air on a proper lift and check my valley drain tube....Don't mind the little rattle in neutral, but I get the buzz saw sound in lower RPM upon acceleration......Grown used to it so it wouldn't hurt to check that drain tube..
Vette73 is offline   Reply With Quote
