Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 05-24-2019   #31
Karl
Karl's Avatar
Default Re: Beast #2 heads to Chicago!
Looks good!
As long as that tube stays put you should be good.
Old 05-24-2019   #32
Originally Posted by Karl View Post
Looks good!
No where to go.
Old 05-24-2019   #33
Karl
Karl's Avatar
No where to go.
Keep everyone updated....you should see much better results.
Old 06-29-2019   #34
Karl
Karl's Avatar
New wheels and tires are on.
Old 03-06-2020   #35
Karl
Karl's Avatar
Everything except the ltpws works on Beast #2!
And that is only because I have the CCW CLASSIC 18's on!
I knew there were quite a few miscellaneous issues that needed to be addressed and the heater core was in need of replacement.
Off to Marc Haibeck for a heater core swap and while you're in there let's fix all the miscellaneous issues at hand.
The car runs amazingly great!
Off to phase 3!
Old 03-06-2020   #36
Like the black center for the wheels Karl. It tames the yellow down a bit.
Old 03-06-2020   #37
Karl
Karl's Avatar
They were originally silver, matching the outter lip. I just sprayed them black.
Thanks for the compliment!
Old 03-07-2020   #38
Always liked a little bit of polished lip highlight to break up the black.
