Old 04-20-2018   #31
spork2367
Default Re: Fuel Sending Unit
Check the socks, both of them. The last batch of senders we received had split/torn filter socks. Since you probably can't get a replacement for the long one, may have to reuse the old one or go with a standard, short one. Not a problem if you do.
Do you know what the AC Delco TS number is for the original long sock with the hole in the end?
Old 04-20-2018   #32
PhillipsLT5
PhillipsLT5's Avatar
ACDELCO TS1
ACDELCO TS3
ACDELCO G1
AIRTEX E3240
AIRTEX E3240
Old 04-20-2018   #33
spork2367
Originally Posted by PhillipsLT5 View Post
ACDELCO TS1
ACDELCO TS3
ACDELCO G1
AIRTEX E3240
AIRTEX E3240
While the ts3 fits and works, it’s not technically correct. The end seams on the original are rotated 90 degrees from each other and the far end has a hole to go over a pin on the housing.
File Type: jpeg 3C0F09D1-943C-49E1-9EBE-8FE5F29E2715.jpeg (76.3 KB, 40 views)
Old 04-21-2018   #34
jss06c6
Gents,
Has anyone upgraded the pumps to the Racetronix (Walbro) 255? Higher flowrate I believe and good quality.
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 04-23-2018   #35
jss06c6
New ACDelco fuel pump/sending unit got here today. Long sock is torn at the bottom heat fusion joint! Guess I'll try to get a replacement, or maybe I can get them t send me a new long sock/strainer? No guarantee that the replacement won't be torn too..same type as in the pic from spork2367 above.
Old 04-23-2018   #36
jss06c6
Jerry,
This is the exact problem I just encountered with a new unit. If I can't get a proper replacement, I'm tempted to reuse the sock from the one I just repaired..
Old 04-23-2018   #37
spork2367
Jerry,
I can’t find the correct long one anywhere. The place you bought it from is just a middle man warehouse, they won’t be any help. The TS3 is close dimensionally. If the old one isn’t brittle I’d just use that.
Old 04-23-2018   #38
jss06c6
Ok.. thanks.
Old 04-24-2018   #39
jss06c6
Torn sock as received.. will put Racetronix socks on the unit..[ATTACH]
Old 04-24-2018   #40
spork2367
You could try heating up two pieces of metal and melting the end back together further back.
