02-01-2018 | #31 | |
Re: 92 LT5 ecu ignition program and control
Fabricating a manifold would eliminate the necessity to plug and smooth the injector bosses but would creat some grief around what to do about the coolant tubes passing into the existing injecter manifolds. |
02-01-2018 | #32 |
An LT5 would look pretty good with 4 Weber DCOE 45s...
... make that DCOE 48s It'd starve with the 45s, even if ya got it to run with carbs... Last edited by Mystic ZR-1; 02-02-2018 at 03:57 PM. |
02-01-2018 | #33 |
02-02-2018 | #34 | |
Looked into the MSD 6010 again today as a ls coil ignition swap option with crank nose reluctor and trigger . Does anyone know the lt5 cam sensor trigger and reluctor setup ? The msd requires a cam signal matching the stock ls1 triggering . Anyone know if lt5 cam signals match ls1? |
