Old 06-29-2018   #31
jss06c6
Default Re: Plenum & Injector Housing Porting
Slow and steady.. one side of the plenum complete.IMG_20180629_101921711.jpg
Old 06-30-2018   #32
Top Toy
Top Toy's Avatar
You may want to consider eliminating the secondaries while you're in there.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 06-30-2018   #33
jss06c6
Thanks, I've thought of this, but my tune brings the secondaries in earlier and I like the way the car drives right now. Cruises nicely and screams when I ask her to.. that said, with the radical change in the primary ports and runners, who knows what #473 will feel like after a new tune..
I'd probably take the secondaries out after a cam upgrade for sure..
Old 06-30-2018   #34
Ccmano
Just took the secondaries out on mine. I’ll let you know what I think shortly. The car will be on the road for the first time later today.
H
Old 06-30-2018   #35
H
I predict you're gonna like the instant throttle response. Subtle, yes. But! Unmistakable! (Did I mention less coking on the secondary valves??
I pulled mine initially b/c of repeated (old stuff) failures. But, later my porting cross sections went beyond 36mm on all ports, leaving the SPTs sorta hanging in the breeze w/ nothing to do. So...OUTATHERE! (And, never looked back. And, NEVER regretting it for a heartbeat...dating back to 2010!
Old 07-03-2018   #36
jss06c6
Flow numbers on one primary and one secondary Port. Using SuperFlo 1020. This is comparison of one stock '90 injector housing vs. one ported '91 injector housing. Longitudinal center of the runners in the ported housing are 32.5 mm, smoothed. The ports are 36.3 mm and the primary injector boss is removed. I suspect a little more is available by opening center up to 36.3 mm, but don't expect much more than 3-4 cfm gain. Secondary showed almost no gain over unported.. again, centers can be opened a bit more..
Will be finishing up, bolting together and running full suite of flow tests on all runners.19219.jpg19221.jpg
Old 07-10-2018   #37
jss06c6
Port matching heads now. IH's and Plenum finished. Next step is to pull the valve covers and send everything out for powder coating.. [ATTACH]
Old 07-10-2018   #38
Top Toy
Top Toy's Avatar
Nice job! You're going to really enjoy the end result!
Old 08-06-2018   #39
jss06c6
Heads port matched. I'm flow testing the assembled plenum/injector housings as well. Next will be removal of cam covers and stripping throttle body down before sending everything out to powder coating. During the wait, I'll be completing the swap to R134, doing a brake job and cleaning the engine valley and front end.
Anyone know where I can get a new set of secondary vacuum actuator valves?
Steve[ATTACH][ATTACH]
Old 08-06-2018   #40
HAWAIIZR-1's Avatar
Nice work and very impressive.You’re a pro!! If you do find new secondary vacuum actuator valves, make sure they are tested to hold and you can return/exchange if defective. When I found my NOS I had to return a few.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
