Old 12-20-2017   #31
WVZR-1
Default Re: WANTED: Cam position sensor for LT5
Until Phil has the sensor and confirms the configuration of the sensor to the cavity the connector is of little concern. I've ID'd the connector shell and supplied Phil with all of the tools needed to evaluate components and eliminate guessing. The terminals and seals need to be selective based upon the wire gauge of the sensor he's considered.
I'd say the project is 'under control'!
Jeff - your sources are valid for parts. I used another but I was buying in bulk when I was purchasing.
Old 12-20-2017   #32
secondchance
Is this the connector we are looking for?
If the sensor is correct minus the connector, re-pinning should be relatively easy.
https://www.walmart.com/ip/Dorman-64...&wl13=&veh=sem
Old 12-20-2017   #33
WVZR-1
Hello Yun - good find. Interesting but it's a long way around to get to where you want to be. You also have to question the Dorman assembly. Some of these after-market connectors while they "mate" correctly they're assembled with completely different terminal retention etc. They won't always 're-pin'.
For that price a person could buy enough components to build maybe 4 of the correct harness connectors. Right now like I mentioned Phil should have information and until the sensor compatibility to the cavity is confirmed there's no rush to the connector.
Actually if a person such as Young1 had a known good connector on a defective sensor he would only need the sensor, transfer his conduit, buy 3 terminals and 3 seals for the terminals assemble and be done.
Old 12-20-2017   #34
secondchance
Hey, Dave! Hope all is excellent with you.
I have been busy tracking down correct GM connectors since I have been having a lot of "oh-s**t" moments breaking OEM connectors while disconnecting them. Price you pay for holding onto 23 plus year old car... AC Delco use to have an excellent webpage where you can list AC Delco connectors by male/female and number of prongs. For some reason, I cannot find this web page. Could it be that GM really wants us to walk away from 20 plus year old cars and buy new?
Old 12-20-2017   #35
tnova
My sensor was cracked where it bolted to the head. I made a JB Weld repair but would prefer to replace the sensor prior to reinstalling the engine. Looking forward to the results.
tnova is offline   Reply With Quote
Old 12-20-2017   #36
Default Re: WANTED: Cam position sensor and Dual mass flywheel for 1990 ZR1 LT5
Here you go
I’ve got everything but the grey holder but that can be transferred onto the new connector,even have the OEM PACKARD wire crimper and the release tool. I’ve got 2 boxes of all his stuff but can only find one. I can post pictures on the Z page on Facebook.
Old 12-20-2017   #37
For some reason I don’t see an option to post pictures on the Z Registry.
Old 12-20-2017   #38
Ccmano
Go to the user CP, upper left. Then pictures and albums on the left.
I use tinypic.com very simple to use app on my iPad and iPhone. A little clunky on windows.
H
Old 12-20-2017   #39
H
The pictures are on the Z page on Facebook.
Old 12-20-2017   #40
A1990
A1990's Avatar
Picture from Jeff:
Another picture
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
