12-06-2017 | #31 |
Re: May be of interest to Mobil 1 users.
I pay $11 a quart for the Amsoil, and I believe I get it from a guy a town over, who is a whole seller....I'm a preferred customer as well. And I notice none to any chain rattle when I have a fresh change...
Sent from my XT1585 using ZR-1 Net Registry mobile app |
12-06-2017 | #32 |
Being a preferred customer I buy direct from Amsoil.. ~$8 per quart
I buy OE Amsoil for my other cars at ~$5 quart Wondering if the Z-Rod oil might be better than the AMO for the amount I drive and having to store it each year. cost is a bit better than the AMO for the Z-Rod
12-06-2017 | #33 | |
Let me start by saying that I am not a chemist. I too used to add a bit of ZDDP to my Mobil-1. In a protracted discussion on oil, likely on the Corvette Forum, someone presented a very sound and incontrovertible argument against doing it. Not enough, and you risk engine damage. Too Much; You ensure engine damage. I had used Mobil -1 exclusively since 1976..... but after that day I switched. I still use Mobil -1 in all of my newer cars, but Mobil deserted our older cars by changing the formulation, so I now have deserted them for the ZR-1 and other non roller cammed engines. Amsoil certainly has what is needed, and you cannot go wrong with using it. I do on occasion. However I also use Brad Penn 10w30 Partial Synthetic High Performance Oil. It provides the needed Zinc / Phosphorous and ZDDP. Brad Penn is the newer name for Kendall GT which I used as a youngster. It is made in Bradford Pennsylvania at one of the oldest oil wells in the country. It is also $8.00 a quart. I no longer buy, use or recommend adding ZDDP unless you have an advanced chemical engineering degree, and proven experience in blending an additive package that does not conflict with it's own ingredients. Buy Amsoil or Brad Penn and then use your brain for simpler things like world peace or assembling rockets. Marty |
12-08-2017 | #34 |
Amsoil for me.
12-08-2017 | #35 |
This oil discussion thread and discussion of zddp begs the question...
While low zddp levels in modern oil is a known and verified source of cam and flat tapped wear in older design engines, has there ever been a verified case where this happened on an LT5 engine? I’ve been around the LT5 engine for going on 10 years now and I can’t honestly say I have ever heard of one. Has anyone ever asked Haibeck or Cory Henderson if they have run across one. Just curious.... H
12-08-2017 | #36 | |
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 12-08-2017 at 02:06 PM. |
12-08-2017 | #37 |
12-08-2017 | #38 |
Jeff,
Marc's comments regarding Mobil1 High Mileage reference the Mobil Oil Chart from 2011. As of 2017, the zinc/phos content is now 800/900 which he states is an unacceptable level.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 02:10 PM. |
12-08-2017 | #39 |
I read on this forum somewhere that the Mobil 1 High Mileage is better for our car than the Extended Performance. Is this still true?
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
12-08-2017 | #40 | |
This one for example is designed for exactly the situation we are discussing. It is designed to treat 4-5 gallons of regular or synthetic oil and is designed to be added every oil change. https://www.summitracing.com/nv/parts/isk-zddp So, sure you can screw things up by not following directions or if you want to play it super safe you can just buy Amsoil (in this case). To each his own I suppose. Have a great Holiday Marty H
