#31 |
So you're saying I should have left it there? I just threw it away... I don't get it. Could it be related to my issue? Do you think I can get another one at the dealership, or somewhere else?
#32 | |
![]() Join Date: Dec 2003
This was someone’s idea of how to increase fuel pressure, by blocking the fuel pressure regulator vacuum source. Probably thought it might result in more power. Toss the foreign piece & reinstall the vacuum hose. Sent from my iPhone using ZR-1 Net Registry
#33 |
By blocking the plenum vacuum to the FPR, fuel flow would be inconsistent throughout the range of engine vacuum resulting in either too much or too little fuel.
#34 |
Alright! I don't like to see that kind of stuff on my car. I hope I won't find other stupid mods like this!
Thanks guys! |
#35 |
![]() Join Date: Aug 2015
What the hell?? Sabotage?? No rational reason unless some other means of fuel management is installed.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#36 | |
is if you wiped away the DAG sealing compound around the secondary throttle Plates thinking it was dirt build up I did that! I removed that plate because I thought I had to remove the plate to remove the plenum. The gasket there was super-worn and there was some coolant coming out of there if I remember. Could this faulty gasket cause all that mess? Hopefully Jerry sells it! |
#37 | |
If you meant “throttle body” and not throttle plate, disregard above. |
#38 | |
I already ordered the gasket via Jerry's website but I wonder if it'll fix my problem. ![]() |
#39 |
If I read this right, that gasket is for the coolant crossover in the throttle body.
#40 |
The DAG is inside the throttle bores sealing the throttle Plates when closed. If you extend the line at #10 into the throttle bore, thats what I mean.
H ![]() |
