#31 |
![]() Join Date: Dec 2003
Grazie Dom! That's the best compliment one could ask for!
#32 |
#33 | |
#34 | |
Q: What automobile industry specifications do your antifreezes meet or exceed? A: Prestone® Antifreeze/Coolant meets or exceeds the performance requirements of the following specifications: ASTM D3306 SAE J1034 GM 1825M Ford ESE M97B44-A Chrysler MS7170 General Services Administration CID A-A-52624 |
#35 | |
This is the Canadian Q&A. The US Q&A section doesn't show this. Will wait to hear from Prestone. |
#36 |
#37 | |
![]() Join Date: May 2010
Thanks. I was going to do the same when I researched Prestone of Q&As this AM to be sure. Not sure why they don't list it on the container. Doing a search on Peak website only one of their products is indicated with GM 1825M spec for our cars called Ready Use Green. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 04-01-2017 at 09:24 AM. |
#38 |
![]() Thanks for confirming. I know I used standard Prestone before in the past. It might be my only choice here. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#39 | |
#40 | |
I usually go for -20 deg more or less with Zs not driven in winter but under cover in shed/garage. If you are in warmer climate you may go a bit less antifreeze but anti freeze also does serve multiple purposes (anti rust, raises boiling temperature) in addition to obvious protection from freezing temperatures. I usually will refill with a gallon or a bit more of antifreeze and about gallon or bit less distilled water then top off white plastic overflow container under passenger headlight with pure antifreeze within an inch or two of top of that plastic reservoir. This is if you only removed a bit of coolant for Plenum Removal...I have TB coolant blocked so do not have to remove any coolant for Plenum removal. Which white plastic reservoir I check after each of two or three heating cycles to make sure it is still topped off. I check before and after refilling/re-filling with 5 ball tester (I recall) and shoot for 3-1/2 balls floating (that is 3 balls floating and the 4th ball in suspension). 3 balls floating.......-10 deg F and +261 deg F 4 balls floating.......-25 deg F and +266 deg F Now if you drained more coolant as in replaced water pump and radiator.....use more than 2 gallons approaching 3-1/2 gallons coolant more or less. If you removed engine and are now replacing coolant......use more than 3 gallons.....maybe approaching 4 gallons more or less of coolant. but do remember to go through several heating cycles after coolant replacement to top off with in 2 inches of top of that plastic coolant overflow under passenger headlight. You fill the coolant using the Top Black Reservoir just in front of the passenger side windshield under the hood. ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-01-2017 at 11:42 PM. |
