Old 04-11-2017   #31
HAWAIIZR-1's Avatar
Default Re: Rear View Camera Install
Nice job Dom! I want a rear view camera too. In fact I want one in the front before I end up taking off my Yokohama BSM bumper too. Thanks for sharing!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-11-2017   #32
Now you've got the connector you need to work with unless you also put your hands on the C209 and it was easier to manipulate.
Were it here I might choose the 8 pin mating for the C209 because it might be easier to unlatch, remove the wire, crimp a new terminal with a pigtail to use for the RVC. The terminals are an easy source for me.
The first image I posted way back isn't in the '92 and earlier FSM because the CDM is right there also and they couldn't image that area as easily under the dash. Get the CDM out of the way and it should be much easier and maybe resemble the later image I posted back there.
Dave,
C209 was pretty accessible once u remove the kick panel. Working upside diwn is always a hoot. Its always a bit of a pain to unclasp these conectors, not too much of an issue to re-pin. I have those pins for use on other connectors. So the re-pin was fairly straight forward. The biggest issue was getting the pin back into the cavity w the extra girth of the additional wire.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-11-2017   #33
Craig,
The appradio4 will accommodate front and rear.
Old 04-12-2017   #34
HAWAIIZR-1's Avatar
Craig,
Thanks Dom! I'll start to look into this. I have to stay off here since you guys with great ideas always cost me more money...lol.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
