02-15-2017 | #31 | |
Re: Is there a market for boosted application?
very competitve power levels while still retaining good mileage economy, and idle quality. I think that these characteristics have led GM back to the DOHC architecture. Perhaps the experience w the LT4 has led GM to look for NA power and away from FI. Ford has demonstrated the potential of an American DOHC motor. If I was going to choose FI, I'd go Turbo over SC.
02-15-2017 | #32 |
stock zr1s run too much compression for much boost/new motors with more sensors and direct injection allow higher compressions but not in the 12 plus range/while the low end or lt5 motors would probably handle boost,top end not so much
02-15-2017 | #33 | |
Stock LT5 can handle around 5 psi. HP and TQ gain is outstanding for this small amount of boost especially the area you gain under the curve. You can run higher but care must be taken or you'll push out the head gaskets. Ask me how I know... There should be an old Dyno Graph post somewhere here the website. When I get home I'll look on my old harddrive. Cheers, Ron
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
02-15-2017 | #34 |
Hell, I'd be ok with 5 PSI. For now. It's like the gopher meal in O' Brother Where Art Thou. I'm afraid 5 PSI might just increase my cravings for more.
02-16-2017 | #35 | |
On the 944/951s people starting sleeving the cylinders with cast iron sleeves, or they would pour concrete into the base of the engine block to help stabilize the cylinders. http://rennlist.com/forums/944-turbo...ilization.html Just some food for thought. Issue is building our LT5's is so damn expensive.
02-16-2017 | #36 |
Closed deck sleeve upgrade is good one for going with more boost? Together with MLS gaskets. Todd makes closed deck sleeves for the LT5.
02-16-2017 | #37 |
Jitse,
I don't currently have any in stock, but can get them. Finding a good quality machine shop to prep the block for installation is crucial.
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
02-16-2017 | #38 |
It's the studs that stretch and cause the head gaskets to fail it has nothing to do with the gaskets. We had the same problems with m3's solution was to use larger head studs.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
02-17-2017 | #39 |
You all complain about Collector value and with every modification this value will go down!
02-17-2017 | #40 |
I have the car for my own enjoyment, and like to improve. If other people like to keep them original its their choice.
