Old 04-09-2017   #31
Default Re: Fuel Jumper arrivals
Originally Posted by PhillipsLT5 View Post
Well guess what I needed last night, yep going 74 MPH on hiway in cruise control & engine dies out, will restart & run for 1 or 2 seconds & die again, thanks guys for making these, it got me home
Another limp home fuel jumper investment success story! WTG Phil
Old 04-09-2017   #32
Originally Posted by George45 View Post
I need to put a little piece of paper with instructions with mine.
Im old and have CRS.
Just remove the gas cap. Pull up the square rubber boot. Pull the fuel pump harness clip away from the edge of the rear fiasca. Unplug the connector by removing the grey lock pin that mates the female and male fuel pump harness connector together and plug in the fuel pump jumper in between that harness. DONE.... Easy and truely plug and play. GC
Old 04-09-2017   #33
George45
Thank you. Just copied it and mailed it to myself. Will print off two. One for the wifes and one for mine. Will go over it with her since she drives hers more than i do mine.
George45 is offline   Reply With Quote
Old 04-09-2017   #34
No sweat
Old 04-09-2017   #35
Mystic ZR-1
Mystic ZR-1's Avatar
The jumper's a must have item!
Used mine to T/S a failing primary fuel pump.
Old 04-09-2017   #36
karlaw
How and where do I get one of these ? Maybe it might help me get 2 zr1 cars to start this year.
LT5
karlaw is offline   Reply With Quote
Old 04-09-2017   #37
HAWAIIZR-1's Avatar
Thanks for the reminder. Daryll's tool does me no good on the shelf. Need to carry it in the Z.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-09-2017   #38
KPW
KPW's Avatar
I'm in the same boat, this post just got mine into the car. Thanks!
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 04-09-2017   #39
2ljd
Already in the car, but my problem is the Z hardly sees the road. Hopefully that'll change soon. 🤞
2ljd is offline   Reply With Quote
Old 04-09-2017   #40
Hmm if enough interest it may be time to make run number 4 !
