Old 07-24-2016   #31
nelson007
nelson007's Avatar
Default Re: Euro Taillamps installed
Thanks Dom
QUOTE=XfireZ51;245505]Please no. I am sure everyone appreciates the contribution. I took the Brake Applied signal from the CHMSL line and connector. You can find it right behind the pillar courtesy lamp on the passenger side. Used a "scotch lock" to tap that line. Then ran a line along perimeter of hatch opening and drilled a small hole to snake that line through to rear. used silicone to seal it.
Split that line into 2 and connected to each side of brake lamps.
As u did, I was able to remove the white wire from the brake switch assembly without cutting it. I put some heat shrink over it. Anyone want to return to stock, it will be a very easy process to reconnect the lines.[/QUOTE]
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 07-24-2016   #32
WVZR-1
Thanks Brett.
Here's a thought starter. If GM did, in fact, mean to have the ZR-1 be the answer to European supercars(they went through the trouble of introducing it in Europe)
Maybe the Euro lamps should have been standard issue, further distinguishing the ZR from the mere mortal C4.
I don't believe that at "introduction" or throughout the C4 production run "AMBER directionals were DOT approved, but it maybe wasn't even regulated. I think that maybe at some point in the mid-2000/2010 NHTSA mentioned that they felt AMBER maybe reduced collisions so they were introduced maybe first on "world distributed" product.I don't know when/if they were approved but I believe that it's still a "choice" of the manufacturer which to use. AMBER I believe is seen more in regular production just because it mandated in most of the world and an accepted option here in the US.
I believe I've seen (in the 80's/90's) earlier European production when presented for VA safety inspection "failed" until RED was substituted.
The secret is in here I'm sure!!
http://www.ecfr.gov/cgi-bin/text-idx...e49.6.571_1108
Old 07-24-2016   #33
Here's something else to think about. The only negative about running the Euro taillights is when the brake switch fails for the CHMSL you have no brakelights. It's already happens to mine and we all know how often the CHMSL fails because of a bad switch.
Old 07-24-2016   #34
Vette Guy
Vette Guy's Avatar
I've got them on both ZR-1s, and love them. I do have a schematic somewhere if someone needs it. Note that there are 2 different versions of the light - some simply have "Guide" written on the lens, and another version has "GM"
and some additional raised markings. Rich had the only set of "GM"s I've ever seen.
"GM"
http://www.corvettemods.com/assets/i...cp-14399-1.jpg
"Guide"
http://i289.photobucket.com/albums/l...4/IMG_1214.jpg
Regards,
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 07-24-2016   #35
Mystic ZR-1
Mystic ZR-1's Avatar
Anybody have a set for sale?
Old 07-24-2016   #36
BigJohn
BigJohn's Avatar
Mid America motorsports part number 614134
Old 07-24-2016   #37
Mystic ZR-1
Nope!
Old 07-24-2016   #38
nelson007
nelson007's Avatar
Mark I could use a copy of the schematic for the lights.
Thanks,
Nelson
"GM"
"Guide"
Regards,
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 07-24-2016   #39
nelson007
nelson007's Avatar
Doug I might have a set of the soild orange.
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 07-25-2016   #40
Last I looked MAMO said they were out of stock.
Mark,
I'll check tomorrow, but pretty sure mine say GUIDE.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
