Old 03-22-2016   #31
Hib Halverson
Default Re: Nitrous
Originally Posted by tpepmeie View Post
No, because I presume you'd want to still have access to full power operation when off the bottle.
What I'd recommend is wire the window switch into an open input on the ECM and apply a spark retard when active. Alternatively, you could have the PT Open spark tables active when the window switch is closed (versus when the secondary bit is set). This becomes a lot easier if you don't have secondary throttles.
Note: the later calibrations have exactly this feature, although the tables are zeroed. The EBTCM sends a binary signal to the ECM, which then retards timing by a specified table amount. That was the secondary form of traction control (spark retard), the first being mechanical throttle modulation.
Ah...good old Todd...always thinkin'
For almost as long as I've owned a ZR-1 I've always wondered why the LT5 TCS never used spark retard. The system was designed to be three steps.
1) Spark retard
2) TPS reduction
3) rear brake intervention at lower speeds only.
As Todd says, all the LT5 cals had that table zeroed.
It'd be pretty easy to use the shifter gun switch or whatever else you use for nitrous enable to control a relay whch would in turn switch a 5V signal to the ECM in place of the signal from the EBTCM.
Then you could just put, say...a 5° retard value in the the TCS table in the cal.
Lastly, on nitrous oxide rigs for LT5, while NOS may no longer sell the LT5 stuff, the guys who originally designed that system are back in business under a different name, Nitrous Supply. It's owned by Corvette nut and the founder of the original Nitrous Oxide Systems, Mike Thermos. 714-373-1986 is the ph. there.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-23-2016   #32
Billy Mild
Default Re: Nitrous
1) Spark retard
2) TPS reduction
What was special about NOS kit? Did it ja e a way to make it safer to run? Looks like the Zex kit already fits the bill.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 03-23-2016   #33
Hib Halverson
Default Re: Nitrous
Then buy the Zex kit.
Old 03-25-2016   #34
Default Re: Nitrous
nitrous bottle holder arrived as did window switch; also have 55, 65, 75 shot fuel/nitrous jets
Old 04-14-2016   #35
Default Re: Nitrous
Well I have all the parts
MSD Window Switch, Zex system with TPS switch, and a MDS DIS-4 Plus which will allow me to easily adjust timing in addition to providing few other protection features. Now I just need the time to install
I was able to get the DIS-4 cheap as it was a display model, the system uses part 8870 to sit between the coil housing and coils to control timing.
https://www.msdperformance.com/produ...ss/parts/62152
https://www.msdperformance.com/produ...ols/parts/8969
https://www.msdperformance.com/produ...ess/parts/8870
Old 04-14-2016   #36
edram454
edram454's Avatar
Default Re: Nitrous
cant wait to see you install it. Hopefully you take pics. You car should really run good.
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 04-14-2016   #37
Billy Mild
Default Re: Nitrous
Take lots of pictures PLEASE. This is for the better of the whole group.
Looking for a ZR-1
Old 04-24-2016   #38
aafc
aafc's Avatar
Default Re: Nitrous
Came across this Nitrous assisted system to keep your bottle at a consisted
pressure . Check out www.nano-nitrous.com . this info is from 2008.
no bottle heater needed pressure stays consisted.
aafc is offline   Reply With Quote
Old 04-25-2016   #39
BigIke
Default Re: Nitrous
I was thinking the ZEX would be the best fit... Can't wait to see it completed!
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
Old 09-04-2016   #40
Default Re: Nitrous
just got done setting up the window switch and Nitrous Management system, all working properly.....need to put everything back together and clean up the wiring, get a tune and refill nitrous bottle.
