Old 05-22-2016   #31
Default Re: Clutch recommendations
Originally Posted by SCCAForums View Post
For those with stock ZR1's, are there any oem equivalent clutch and pressure plates that still will work with OEM Dual Mass Flywheel?
Best Regards,
Dave
The "replacement" available today for the stock clutch is the L98 & LT1/4 version which is a shorter height pressure plate that is also 300lbf less than the stock ZR-1 unit. It will work but requires pressure plate bolts for thew L98 & LT1/4 which are shorter than the ZR-1 pressure plate bolts. (IMPORTANT if you want the clutch to work after it's installed )
Available @ Rock Auto & probably your local auto parts store.
Valeo PN 52802204.
Old 05-05-2017   #32
efnfast
My car is at Pete's getting upgrades. Pete found a few little quirks with the install, but no smoking guns. So, I bought and paid for a new disc and pressure plate from Ram. Time draws close to MR5, so this was the fastest thing to do. If this one also slips, I'm screwed.
New clutch shouldn't cost as many thousands of dollars as this has.
Old 05-05-2017   #33
BigJohn
BigJohn's Avatar
Are you changing all clutch components?
Paying someone depending the hour rate; maybe $2500 to $3500!
Old 05-05-2017   #34
efnfast
All the components were changed and didn't work.
Old 05-17-2017   #35
5ABI VT
Tough to have to read about these issues. Are you still using the fidanza with the Ram setup?
Old 05-18-2017   #36
efnfast
That was my original plan, but the ram stuff won't work with the fidanza. So, I have a nice fidanza for sale.
I've got about 1500 miles on the new set up. No slipping, but it's grabby and has no give to it. Stock set up is much softer.
Old 05-18-2017   #37
Said this over & over...............anything under 550 RWHP the stock clutch setup is tough to beat.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-18-2017   #38
BigIke
Which #FW did you buy?
Sent from my SM-G950U using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
