10-27-2015 | #31 |
Re: Stalling issues - Code 31 (Camshaft Position Sensor)
OFF button doesn't fix the problem, but AUTO makes it worst.
Personal guess: could it be the battery? |
10-27-2015 | #32 |
Car also pulls definitely stronger when heater is at OFF position.
10-27-2015 | #33 |
And another update: as soon as the RESERVE light came on, car ran like COMPLETE ****, scary. SES light came on more and more when the tank was becoming more and more empty.
Put 4 gallons of gas: no more SES and engine doesn't run like **** anymore. Oh my god... |
10-27-2015 | #34 |
Fully tested the battery now.
Battery is fine. |
10-28-2015 | #35 |
I had the very same symptoms and was getting a code 31 with the paper clip. Went thru the diagnosis with the service manual. Still could`nt locate the problem. Got a used sensor from a member who bought a new one and didn`t need it. Problem solved.
10-28-2015 | #36 | |
Just a bit-o-info for ya:
Sounds like the previous owner left several 'gremlins' for the next guy to 'discover'. When I got my 90 it had several; mostly under the plenum. But, once cleared of all the neglected maintenance items, she's been 'running wicked' ever since!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 10-28-2015 at 08:35 AM. |
10-28-2015 | #37 |
alot of time the car sits and the fuel pumps become an issue check the fuel rail pressure tape the gauge on the hood so you can see if the FP holds as you go WOT
FSM is a must have. and scanners are nice too to monitor the fuel trims so you can see what's going on. I have EASE but it's overkill and there are much cheaper solutions. with a bit of persistence the problem will be revealed! the botherhood of the beast is a tight knit group and we will help you! if anyone needs the early FSM, I have a spare set, $75 + $15 shipping and they will be at your door! just PM me.
10-28-2015 | #38 | |||
-Connected the sensor to a 7 volts battery -Looked at the voltage through multimeter. Showed 0 when the magnet was near metal and 7 when it was in the air. -Initial scan showed no signal coming from the cam sensor, which makes no sense now. Will consider a used one if I find one though and I won't put that possibility in garbage now. Thanks Richard! Quote:
No it is no a low fuel issue all along, I'm having the problem with a full tank of fuel. But like I said, it seems to be worst when the fuel is getting lower and lower. Maybe I should have told you before that last winter, the car was left outside and it snowed on it. Water came in the fuel tank via the fuel cap and the fuel tank froze. Quote:
I don't really know where to tape a fuel pressure gauge, but that's the next thing I'd like to do: check fuel pumps pressure. Especially because I've red that there's only one pump where the car is cold (everything runs perfectly A1 when cold). Can't find much on the forums, unfortunately. I feel like a student who forgot his books at home, can't wait to receive the FSM. What are the specs for fuel pressure? Thanks a lot, I can see this is an awesome group! I'm a member of RX7Club since 2007 and I can already tell that the Registry is way friendlier. |
10-28-2015 | #39 |
10-28-2015 | #40 | |
Update: -Fuel pumps hoses are OK. -Just red the codes again using the paper clip - only Code 31 shows up, again. |
