Old 07-22-2015   #31
Bob Eyres
Default Re: Swapping shifters...
They made them in both colors.. they may not make them anymore.. BUT
White
http://www.ebay.com/itm/HURST-C4-Cor...25.m3641.l6368
Thanks Jeff. Just ordered one. I don't know why that didn't pop up in my searches.
Old 07-22-2015   #32
White
Black
http://www.ebay.com/itm/Hurst-6-spee...25.m3641.l6368
I have the white one but don't recall it coming with the jam nut. Does anybody know if the jam nut can be bought seperate from the ball?
Old 07-22-2015   #33
WVZR-1
If the knob is still in the original package the jamb nut actually positions the ball in the blister pack. It's only a barrel with two flats and not a hex affair.
The nuts are nearly always on eBay also. 9/16-18 Hurst nut should get you there.
Old 07-23-2015   #34
edram454
edram454's Avatar
I just bought a hurst shifter with a black hurst engraved shifter ball and it does come with the nut in the package.
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 07-23-2015   #35
Where and how much for the shifter??
Thanks in advance, guys!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-23-2015   #36
http://www.hurstshiftersonline.com/p...?idproduct=291
http://www.ebay.com/itm/Hurst-391508...fa1255&vxp=mtr
Old 07-23-2015   #37
I think the ball I bought years ago was a knockoff so I just bought one on EBay,don't really matter cause I can't find the damn thing. I did find at least one Hurst shift ball,white on Amazon for about $40 shipped. I'm going to attempt the shifter install this weekend in my one car garage. Wish me luck,sounds like a YouTube moment in the making. I'd post some pictures but not sure how from my iPhone.
Old 07-24-2015   #38
edram454
edram454's Avatar
Paul,
I believe I paid $164.00 for the shifter and about 40 dollars for the ball. the ball is black with white engraved shifter numbers for our shift pattern and it has on each side "Hurst" engraved also. This will be installed in my car next month. I bought them both on ebay.
ed ramos #3028
EDRAM454
Old 07-24-2015   #39
Thanks for the cost info. That project is now on my "list"! I just need to read up on how it is done on a ZF trans and 'git er done!!'
90 #1202
Sans secondaries
Old 07-24-2015   #40
Billy Mild
The shifter swap is a PIA. I didn't drop the exhaust and it was a pain to get the pin out. Getting it back in wasn't either. When you are putting the pin back in keep in mind you might need another person to hold the shifter while hammering away. I also do not have a punch. I only have rachet extension and what not.
After it being done, the shifter is awesome. Make sure to lube all the interfacing surfaces, once it warms up and you drive it a bit the shifter will loosen up a bit.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
