Old 04-26-2015   #31
JimZRyd
JimZRyd's Avatar
Default Re: Cheap "thrill" ho-boy.
I recently picked one of those up from the Gadget Man. Haven't used it yet. Seems very well made!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 04-26-2015   #32
Yes it is.. I modded mine for use with a bottle jack.. works good..
I still need to find a good way to put the car on jackstands while on the Kwik-lift
Old 04-26-2015   #33
I have two of the black cross members (like shown in the photo) to support jack stands, hydraulic jacks, transmissions.
Old 04-26-2015   #34
mike100
I want a lift but it will cost me half a million dollars in San Diego Co.
Old 04-26-2015   #35
Cliff,
My jackstands look like yours in the pic. Only mine are black.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-26-2015   #36
Yeah I have 2 of those bridges and they work great.. especially the front.. That is easy to get on stands..
Tell me where the good spots are in the back, there are none that work well with the Kwik-lift that I have found
Old 04-26-2015   #37
Cliff,
Those are not my jack stands.....just found that for illustration.
My jack stands are identical however but Red in color (heavy duty).
That is not my KwikLift ....this is
Both black Bridges are shown.
Also shown with my rig for winching a ZR-1 onto KwikLift (no engine)
Old 04-26-2015   #38
I have to look.....but I am thinking either jack up at the normal jack point just in front of rear tire with jack on quick lift (roadway) and then support center of jacked up leaf spring with adapter and blocks on the bridge. Or jack up with adapter on center of leaf spring and support normal jacking points in front of rear tires on blocks on quick lift (roadway).
But have to look more closely.
Oh....I am assuming you want to maybe remove rear differential/short shafts completely with ZR-1 up on KwikLift?
Old 04-27-2015   #39
Yeah that is what I do now, but Would like to find a better way to lift it in the center.... Hmm maybe off the Leaf spring mount.. That could work..
struggle is getting the car on the lift and clear the tube so I can use the bridge at the back
Old 04-27-2015   #40
I use a extra strong short pipe section under the center of the heavy leaf spring between the four main bolts holding that spring in place. but some have said that extra strong pipe section does not fit easily between the stock exhaust pipes behind the differential (fits perfectly with SW Exhaust).
I think I did jack up the ZR-1 with the extra strong pipe section and stock exhaust however. One advantage is that the rear of the ZR-1 is rather light compared to the front
Lifting and Towing the ZR-1
Now if you want to have fun.....get these mats to keep your ZR-1 dry from condensation (Mid West Guys) and the floor all around the ZR-1 NON SLIP
The mats are 3/8 closed cell foam 2 ft x 2 ft interlocking squares (easily disassembled and rearranged as you like).
