#31 |
I forgot to post a few pictures. I should have taken more, but we were trying to get things done.
![]() Oil vapors were being vented to the atmosphere. I don't understand how this car ran at all. ![]() In this picture you will see a mouse nests. Guess what? There was a crispy dead mouse still in there. Surprisingly there are no chewed wires. ![]() |
#32 | |
You might ALSO have air getting by the TB 2' butterflies, as I mentioned above. Mouse needs butter (he's toast) ![]() |
#33 |
I didn't remove the TB at all, also I didn't clean the inside of the plenum at all.
#34 |
#35 |
Yes I did remove the throttle cables.
#36 |
![]() Join Date: Dec 2003
Did it idle properly at 750rpm before you did the work?
#37 |
In general the car didn't run very well before this work. But it did have a consistent idle.
Now the car runs better, much better, but the idle is not consistent. As far as I can tell there aren't any vacuum leaks. I tried spraying potential vacuum leaks with WD40.there was 0 change. Could be TPS or IAC possibly? |
#38 |
I doubt that its the TPS or IAC, if they were not removed. I am more inclined towards a vacuum leak associated with the work that was done. Its not unusual to have a cracked hose or leaking connection when re-installing the plenum. It's a little tricky keeping it all connected. You should backtrack your work.
#39 |
Is there anyway to check this without pulling the plenum again?
#40 |
![]() Join Date: Feb 2011
take the intake bellows off and take a stiff box cardboard piece (like real stiff) or a phone book etc and block the air horn to see if you can stall it. An open tube will be audible enough if the engine is still running at that point.
