08-16-2014 | #31 |
Re: Sagging headliner ... (snappics)
Now carefully flip the boards, and repeat the 3-strip tape procedure. You shouldn't be able to raise the second board very high at all now, because the first taped side is now binding. The masking tape will SLIGHTLY stretch however.
Now put another strip of tape vertically along the adjoined edges of the 2 boards, across the 3 strips, on both sides. Tape from end to end (exceeding the 24" size of the template). Press down well, and THEN SLIDE THE BACK OF YOUR FINGERNAIL UP AND DOWN THE TAPE, ALONG THE JOINT OF THE 2 BOARDS. With the joint binding, it probably is not perfectly joined level. This will accomplish that. Do it both sides. Now tape the paper frame template to the 2 foam boards, and trace the outline LIGHTLY on the boards. The template doesn't have to be exactly centered on the foam board. No snappic here; I didn't use a paper template - I used the board cutaway from my painted top re-enforcement. You now need a VERY SHARP knife - preferably a single edge razor. DO NOT CUT THE TEMPLATE LINE. Cut approximately 1/4", OR MORE, OUTSIDE of the template line, for 2 reasons: 1) you have to allow for the compound convex of the top surface, and 2) allow for error. Cut slowly. Probably DON'T attempt to cut all the way through on the first pass. I didn't even cut on the first pass; I scored a line, with my Victorinox blade reversed. This cut will require patience too. Even in front of a single edge, the foam can 'bunch up', in front of the blade (another reason to go 1/4", at least, outside the template line). You might also want to not cut all the way through; rather cut until there's an outline on the backside, then complete the cut from the other side. The cut edge of the board can be, and will need sanding. I used 120-grit paper. A sanding sponge of comparable grit will work well. Sandpaper will be needed anyway, for the concave forward corners. Before you start sanding, do a trial fit ALMOST inside the Glasstop frame, to get an idea of where you need to focus sanding. Don't press it all the way into the frame; you might not be able to get it out without mangling it. And while sanding, remember that you want to leave slight excess. You can always take it down further, but it's not easy to put it back on once sanded off. Maybe another reason to buy 4 sheets, when they're only $1.25 each. Don't worry if you go a little deep with sanding; the headliner screen's felt will need some real estate. After sanding, I put another strip of masking tape all the way around the foam board, at the joint, to give it just a little more 'strength'. Remember tho', tape is all that's holding the 2 pieces together. Mine seems somewhat sturdy, with moderate handling. Once the felt is applied with the adhesive, and wrapped around, it should have the strength of a single piece of foam. But DO remember this when removing, and installing. Keep your hand with your fingers spread out well, in the center, when removing the screen...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-14-2014 at 01:06 PM. |
08-16-2014 | #32 |
You're welcome there Nelson!
I'm thinkin' here too (see the smoke ), that if you haven't found a suitable pad material, or facsimile thereof, that you can use this foam board. If it will work in a removable screen, and it looks like it will so far here, it surely can be affixed with permanence. Haven't gotten that far yet tho'.................................
08-16-2014 | #33 |
Thought of that too Dom (not for myself tho'); how much the suede weighs, to be held up with the foam pad, and if it would hold up 2 splashes - one facing INside, and one OUTside...
Figured SOMEone's already started on it by now, with splash. (or Eckler's, CC, Zip, etc. ) 2 felts + foam backing = about 4 ozs...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 08-16-2014 at 11:29 PM. |
08-17-2014 | #34 |
[IMG][/IMG]Here ya go.The only downside to using this on the underside of the top,it took about 6 weeks for the smell to dissipate.$50 a quart?..............Add another $30 for the activater.
10-18-2014 | #35 |
Headliners look very nice BUT......due to our GM Licensing Agreement with EMI, unapproved, trademarked GM logo merchandise cannot be advertised for sale on our Forum or through the ZR-1.NetRegistry at any time.
Locking this Thread down and Deleting for legal reasons. Chuck, you'll have to do business elsewhere. FYI Brett
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 10-18-2014 at 06:51 PM. |
