#31 |
Anyone have any info on what size fittings etc are needed to connect this to the factory Pcv system ? I see Tony has 2 cans.. Are there 2 Pcv valves or are you just adding 2 cans in line ?
#32 |
![]() Join Date: Aug 2006
#33 | |
![]() Join Date: Jan 2004
IH port side on the can is 3/4" to accommodate the PVC then reduced to 3/8" which then connects to the IH port tube. Left can is connected to Left side IH. Right side can connected to right IH port tube. Vacuum source is shared via T connector. Below is a diagram for a single can I built for a couple of Z buddies. ![]() Below is a can I built for a L98 which is to be mounted under the passengers headlight. ![]() Yes........... this are used propane tanks. ![]() Single Canister mounted onto my buddies Z. This is the drivers side. ![]()
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 Last edited by Tony Davila; 07-17-2014 at 06:15 PM. |
#34 |
![]() Join Date: Mar 2007
#35 | |
#36 |
![]() Join Date: Oct 2013
#37 |
Sorry brother, I will not be able to make anymore due to extremely busy schedule and upcoming job. It will be a long while.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 Last edited by Tony Davila; 07-21-2014 at 06:11 PM. |
#38 | |
#39 |
What are your guys thoughts on a pcv + catch cans + Piping from catch can to the header collectors (scavenging? forget the term for it).
#40 |
EGR connection? It's an interesting thought. As long as you maintain vacuum crank case fume should get burned off. Is that the idea?
