Old 04-21-2014   #31
Default Re: Vacuum leak? Marc has me confused now!
Pump is there to make up for problem.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-21-2014   #32
Reading this thread again, got me thinking...
As a rule, I agree with Marc Haibeck on most significant issues relating to LT5 performance/drivability, but on the Secondary Port Throttle vacuum system, if Marc feels that as long as the auxiliary vacuum pump will shut off for a second or so, the port throttles will work properly, I disagree.
Key parts of the port throttle system are the vacuum motors which open and close the SPTs, a small vacuum reservoir, the auxiliary vacuum pump, various controlling/sensing devices and the plumbing. The system is controlled by the ECM and can be disabled with the "power switch" or "valet switch".
Once the power key is on and the ECM decides the port throttles should open, engine manifold absolute pressure, which is below atmospheric at the time the port throttles are to be opened, is fed to the port throttle actuators and the SPTs open. Manifold vacuum also is also fed to a small "vacuum" reservoir down under the intake plenum.
As the main throttle continues to open and load on the engine increases, manifold pressure increases to nearly atmospheric. Of course, that's not enough to continue to overcome the return springs in the SPT actuators, so...what holds the SPTs open? For a short period, the lower pressure level in the vacuum reservoir.
Ok...riddle me this: what happens during a period of high part throttle or wide open throttle operation long enough for the pressure in the vacuum reservoir to begin to rise towards MAP. What keeps the SPTs open, then?
Well, that's why GM added an auxiliary vacuum pump to the system. Once pressure in the SPT system goes rises above 61-kPa (or, drops below 41-kPa vacuum), the pump kicks on to keep the pressure in the SPT system low enough to overcome the SPT actuators' spring pressure and hold the port throttles open.
Now, what happens when the system leakage is enough that aux. vac. pump cannot maintain a low enough pressure to hold the port throttles open? If the SPTS are commanded open and MAP rises above 80.3-kPa (or, drops below 21-kPa vacuum) for more than two seconds, the ECM sets DTC61, turns the MIL on and sets the rev limit to 3000 RPM.
So when can a leaking SPT system set DTC61, try climbing a long hill at 80 mph and at higher altitude–say 4000 feet or above. Or try a long acceleration in fifth gear.
The bigger the leak in the system, the sooner that code will set and the pump running once every second seems like a pretty big leak or a weak pump to me.
Bottom line, if your secondary port throttle system leaks or the vacuum pump is too weak to hold a pressure low enough to turn off, for not just one second, but 15 seconds or so, repair the system. The instructions on troubleshooting and repairing the SPTs are in the Service Manual.
SPT fun fact: Peel off the label from the vacuum reservoir under the plenum and you'll find a Ford part number.
Marc should correct me if I'm wrong, but I don't believe he's saying a short "OFF" cycle doesn't need attention, but rather if the leak is small enough that the vacuum pump can attain sufficient vacuum to reach pump cut-off threshold, then the the SPTs actuators will not be inhibited for lack of vacuum (provided code 61 is not triggered). (Referring to the diagram above)
The SPT circuit is divided into two parts, partitioned by the SECONDARY PORT THROTTLE VALVE (switch):
  1. The pump and the engine vacuum charge the reservoir side of the (VALVE) and
  2. the other half of the circuit connects the (valve) to the vacuum actuators.
So, IF the vacuum pump will cycle OFF - for even a second, then sufficient vacuum exists to operate the SPT actuators, at least up to the SPT VALVE (valve). Now, however, if the circuit on the actuator side of the (valve) is severely compromised to the point of triggering code 61 when the ECM calls for the secondaries to open, we know the actuator side of the circuit is what is severely compromised.
Back to Scottfab's point about the short "OFF" cycling and pump longevity:
If a pump is short (off) cycling, I wouldn't argue there isn't an issue to be attended to. However, most of the time the engine provides the vacuum sufficient to charge and maintain the reservoir side of the (valve). The pump doesn't run at all until there is a sustained load to raise air pressure above the point the pump is triggered "ON". This significantly mitigates the concern for pump being over-worked (but I'd want to run that down at the earliest convenience). But, then again, during the 24 hour run, I would think the pump ran (ed. as needed) majority of the time, especially at/near WOT!
Of course one could perform the secondary delete mod and NEVER worry about this entire topic again...But, that is another debate.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-21-2014   #33
Hib Halverson
Here's a page from the FSM.
'Preciate the time to shoot a pic and post it but, you didn't need to do that. I have FSMs from 1982-2012 and have read that page a number of times.
No offense Hib, I appreciate your writing but I'll go with the guy that has worked on LT-5s for over 15 years.
Even Marc's 15 years of experience, which I greatly respect (heck, I've had him work on my '04 and I use his cals in my '95) cannot negate the fact that when an engine like the LT5 is at WOT, there is virtually no vacuum present. If you don't believe me, connect your scan tester and go for a road test. Pick third or fourth gear then accelerate at 100% TPS and watch the MAP reading. It will be very close to atmospheric, ie: virtually no vacuum.
With 90-92, almost all time at WOT, the SPTs are commanded open and with 93-95 it's all the time. Thus, for most of the time the SPTs are open, while vacuum may be present to open them, there's little or no vacuum to keep them open, so the primary source of vacuum is not MAP but is, first, the vacuum tank, followed afterwards, by the pump.
(snip)
HERE's a question for Hib. On the 24 hour run, was there a secondary pump in use?
I never saw the Record Run engine with the plenum off so I can't verify the existence of port throttles on it.
Originally Posted by KILLSHOTS View Post
Could that pump have handled running nearly non-stop for 24 hours?
Might be a moot question because for the entire run (5000-km, 24-hr and 5000-mi), the engine was never run at WOT. It had a throttle stop, so there was always some level of vacuum present. At high rpm, it may have been quite a bit of vacuum because of the restriction part throttle must have been in the intake tract. It wasn't until after they set the 5000-mi. mark that the final driver, Stu Hayner, was told to remove the throttle stop and take a few laps at WOT.
There was a so-called "touch the sky" test done during the final stages of ZR-1 development. I think it was done at the now-defunct Desert Proving Ground where a ZR-1 was run on the high-banked track at WOT for the duration of a tank of fuel so the aux. vac. pump will last at least that long in continuous use.
Marc said EVERY LT-5 leaks to one extent or another. That's why there's a pump.
That is NOT why there is a pump.
HIB, your post was moderated for "some" of its content. PM sent.
Old 04-22-2014   #34
scottfab
scottfab's Avatar
My sense for it is that you are mostly correct. However, running that close to failure is not the best solution. In fact the system is on the verge of failure (code being set) and will dip in and out of failure. This is not by any means or stretch of the imagination a good approach. Why not just fix it and be done with it. To propagate the notion that 1sec between cycles is "OK" is like saying you can run your tires at 25psi and that it's ok to ignore filling the tires until the "Low Tire Pressure" light comes on. I do not recommend either.
Getting above 15sec and in fact achieving 30sec or more cycle time on the pump is not hard. Attention do detail is the key. Really going after and fixing leaks and contamination is key (if you live in a heavy dust filled and/or dirt filled environment then all bets are off)
Yes, one can wait until there is total failure just as one can keep driving when the "RESERVE" notice is given on the dash. I prefer not to and would never suggest that members think it is OK to keep driving when the "RESERVE" light is lit. Similarly, a 1sec pump interval is a BIG TIME warning. AND I submit is not proven to NOT set a code at 1sec pump interval time. In fact I know positively that you'll get a roll off of power at about 4k and NOT see a code 61.
(marginal condition)
Agreed, most of the time if the engine is running. However, I stated
"key on engine off". Not a great concern because it is usually rare for key on engine off but it does happen. This is not a fish pump we're talking about. It is not intended to run 100% duty cycle 24/7.
If a pump is cycling every 1sec with key on engine off, just fix it.
Gezzz
This significantly mitigates the concern for pump being over-worked (but I'd want to run that down at the earliest convenience). But, then again, during the 24 hour run, I would think the pump ran majority of the time, especially at/near WOT!
Interesting, I wonder about "most of the time". My guess would be there is enough vacuum at 174mph to run the actuators with out the pump "most of the time"
On each curve and WOT maybe it's on. Straightaways? dunno
yes that would "fix" it. But then would it be an LT5? One wonders.
I suppose it is. I mean the block is still there.
Back in 99 I came up with a solenoid actuator replacement that pulled a cable. I was convince it would be a permanent solution. However about that time I ended up
actually fixing the secondary system and it has stayed fix all of these years, save the time the rebuilt pump failed (poor selection of replacement diaphragm material) . At that time (99) I announced I would, upon another secondary system failure, put that solenoid in and make public the part numbers etc. So far it hasn't come to that.
I do still have all the parts etc in a box. I think ripping out the secondary is out of the question for me for several reasons.
eh, but then that's just me. I still keep the spare tire and the owner's manual too
Respectfully submitted:
Scott
Old 04-22-2014   #35
Hib Halverson
Originally Posted by scottfab View Post
(snip)
On each curve and WOT maybe it's on. Straightaways? dunno(snip)
Guys...the Record Run engine was throttle stopped so there was always vacuum present in the plenum. If that engine had port throttles, which I suspect it did because the it came right off the LT5 Line at Stillwater, it's likely the pump didn't run that much.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-22-2014   #36
scottfab
scottfab's Avatar
Didn't see your previous post to mine.
Do you know or suspect what the thinking was to put the stop in?
Scott
Old 04-22-2014   #37
Default i am never confused by Marc's advice
BUT, on page 19 of the latest HOTB, Marc says in his troubleshooting tips:
"If the pump cycles on and off the vacuum connections up to the secondary port solenoid are tight. As long as the pump will turn off for one second, the secondary port throttles will operate normally. If the pump shuts off for longer than five seconds it indicates that the vacuum system connections are tighter than average."
So, according to Marc, my vacuum system connections are tight? Am I misunderstanding what I've just read? Anybody willing to help confuse me further?
Thanks!
Chris
I Concur with Marc
If the vacuum pump cycles 5, 10, 15 seconds or at all....the vacuum system is NOT TIGHT but normal and functional for the age of the vacuum system with components not replaced with NEW LINES AND NEW RUBBER (soft) CONNECTORS.
Disconnect the drivers side center plenum vacuum source and hold your finger over the rubber connector disconnected (Engine OFF but Key ON). IF THE SECONDARIES (Secondary Canisters) FUNCTION AND HOLD POSITION WHEN TESTING SECONDARIES WITH PLENUM IN PLACE (Key on) Verifying Secondary Actuator Operation with the Plenum in Place END OF DISCUSSION
I will think further on this but for now I am busy planting corn and beans
Old 04-22-2014   #38
KILLSHOTS
Default Re: i am never confused by Marc's advice
I Concur with Marc
I'll try this. Thanks!!
Old 04-22-2014   #39
scottfab
scottfab's Avatar
Maybe yours leaks a little, which is what I think mine is doing, but it doesn't seem like it must be a big deal, especially since we aren't idling high. I definitely value Hib's input and frankly, what he's saying make a lot of sense, even to my non-engineer mind. But if I parse his expert advice with Marc's expert advice, it seems like I have an issue but not one that I should be pulling the plenum tomorrow to correct.
With key on and engine off how long does the pump run and how long does it stay off (approximately) ?
Scott
Old 04-22-2014   #40
KILLSHOTS
It runs for only an instant...less than a second. Then, it stays off for 4 to 5 seconds. Then repeat.
