#31 | |
What if a connection is reversed at the power key? Is it possible that with a reversed connection, that the power key in 'FULL' mode, is energizing the circuit [s] as though the key WAS in NORMAL position??? --------------------------------------------------------------- zr-1.R1 - it should NOT have been necessary to fabricate the new mounting brackets. What is the model number of the injectors that you have? |
#32 | |
![]() Join Date: Dec 2003
There is something wrong somewhere if you cannot use the correct fuel rail brackets.
#33 |
the code number should be this in the photo below
#34 |
I found the old injectors hard to pull out probably since the o-rings are so old. The new primaries "popped" in place with new o-rings, the new secondaries felt loose until the fuel rail clamped them down.
I suspect a different problem. It is easy to pinch the injector wiring or to have a connector not seated. I would try the ohm test on primary injectors to see if all are "happy" - if one is shorted it may be bad or wire pinched, if one is infinite it may not be plugged in all the way. HTH, - Jeff |
#35 |
tomorrow I dismount the car,I remove the plenum, run detailed photos, then put them on the forum.
I make a test with standard brackets, though I remain somewhat relieved the injectors, then I'll know |
