Old 11-05-2013   #31
Default Re: Got Lucky tonite
Is it P40 or P38. I always thought the Flying Tiger stuff was 38's. I loved the
teeth on the lower engine cowl. Never actually got it to takeoff, then the fuel ate away at the plastic wings until it fell apart. I was left w just the engine and I built an engine mount out of my Erector set and run the motor w battery and fuel. Imagine doing that in a 4 room railroad apartment in Brooklyn. Noisy.
I think the P38 was the dual fin lightning the P40 was the war hawk. Yep thats the one I have tri bladed bugger remember once during the spring start procedure (remember that) not removing the finger fast enough to have the cox av gas get into the wound. That will learn ya pretty fast lol
That happened to mine as well so using coat hangers the wheels and alum cans to mount the engine I built a rear engine powered prop car that terriorized the neighborhood.
Old 11-05-2013   #32
Bearly Flying
Goldy is correct, the P-38 was the twin engine twin boom Fighter, the P-40 was the only front line Fighter the USA had in any numbers when the Japanese bombed Pearl Harbour. Altho the P-40 could not dogfight with a Zero, it was tough as hell and nothing could match it's speed in a dive. The AVG in China, The Flying Tigers, learned this early on and were very effective knocking the Zero's out of the sky.
There were better, faster and more publicized Planes that came later, but the Good Old P-40 workhorse did the bulk of the work in the early years.
Bearly Flying is offline   Reply With Quote
Old 11-05-2013   #33
Yes the P-38 Lightning. I remember it now. Didn't they also call it the
"Black Widow"? The P-51 always struck me as the racehorse of prop fighters.
Old 11-05-2013   #34
The P51 was indeed the race horse of the pack. However for the pacific campaign my favorite was the F4U Corsair. Loved Baa Baa Black Sheep before it was called The Black Sheep Squadron. Pappy Boyington was a stud....
Old 11-05-2013   #35
Schrade
Originally Posted by Bearly Flying View Post
ZoiNKs!
That looks like a DTC 'BAD GROUND' !!!
I had the P40 warhawk all in green and on the string. Remember the glow plugs and the fuel in the can lol
I had this one too; U-Control...
Old 11-05-2013   #36
Bearly Flying
Old 11-06-2013   #37
Schrade
Actually there is one of those hanging in there too. Finished building it, just working on the covering now.
Balsa skin? No fabric / poly- compound? On the rudder? Retractable gear?
Old 11-06-2013   #38
Bearly Flying
It is built with mostly balsa, the covering will be a Plastic heat activated/ heat shrink film in an Olive Drab with light brown camo spots painted on.
The gear is electric rotating retracts, tail wheel also retracts with a mechanical linkage.
It has a YS 91 glow engine that is Supercharged and fuel injected, I believe it puts out around 3.5 hp @ 13,000 rpm. The Plane weights in at about 9 lbs. Not a bad power/weight ratio.
