Old 10-25-2013   #31
cvette98pacecar
Default Re: First C6 ZR1 under 65k.
Originally Posted by Bob Eyres View Post
Where can I get info on this "new" L88? Is it a replacement for the ZR1?
There is no information at this point GM will release the car in January. The ALMS teams cannot use the current LT1 engine for the race cars so it is my speculation that the L88 will be released in January. It will be the replacement for the Z06.
Old 10-25-2013   #32
BigJohn
BigJohn's Avatar
Maybe they can use my 216 Nailhead until they get the new engine!
Old 10-25-2013   #33
Kevin
Kevin's Avatar
why can't they use the current LT1?
Old 10-25-2013   #34
Mystic ZR-1
Mystic ZR-1's Avatar
Big John
Nailhead: the 38's got a Buick motor in it?
I think you meant stovebolt....
Gotcha!!!!
See ya at breakfast!
Old 10-25-2013   #35
BigJohn
BigJohn's Avatar
Big John
Gotcha!!!!
Yep!
I think it's a Hemi!!!
Old 11-03-2013   #36
DennisC
Nice ZR-1 someday I will add one on those to my collection...
DennisC is offline   Reply With Quote
Old 11-05-2013   #37
Hog
Here is a pic of the new LT4/L88 supercharged GEN 5 engine. There are 2 new engines on the way, a 600hp and 700hp version. Sort of like the 556hp GEN 4 LSA in the Cadillac CTS-V and the Camaro ZL1 and the C6 ZR1 Vette/638hp GEN 4 LS9.
The GEN 5 LT1 Stingray crate engine is available complete in both a dry sump and wet sump version. Forged crank/rods/pistons on a base V8 engine.
460hp@ 6000rpm/465 lb/ft torque@4600rpm
p/n 12657236 Gets you a wet sump complete engine
p/n 12657246 Gets you a complete dry sump version.
Cost is $10,700, less expensive than the 427cid LS7 and out torques LS7 until 4000rpm using 376 cubes, LT1 is with 5 lb/ft of LS7 at its torque peak. 90 percent of peak torque available from 3,000 rpm to 5,500 rpm. Has more power density at 74hp/liter than LS3 and LS7.
Over 10,000,000 hours of computer ECU usage on these GEN 5 engines, mostly in the cylinder heads. Direct injection and forced induction are a match made in heaven. The injected fuel is used to cool the incomming air, which allows for more static compression, or boost.
The good old days are here.
Old 11-05-2013   #38
pantera1683
This is quite literally, the coolest thing I have ever heard...ever!
pantera1683 is offline   Reply With Quote
