Old 09-26-2013   #31
secondchance
Default Re: So...How much does it cost to build a 380 cube ZR1?
Originally Posted by rkreigh View Post
will do! I will bring the new headliner tape and spray adhesive too
you are the man Yun! are you going to Kate's on Sat??
I got the "green light" for maintenance day
I'll be at Katie's. See ya!
Old 09-26-2013   #32
secondchance
Originally Posted by alnukem View Post
You know, I tried to make this a education thread, for people new to the ZR1, like me. I felt this might be a good way for someone who was considering building up their car, to give them a place to find answers about a build that would not be as expensive & bump up the torque numbers as a alternate to standard 500 hp 350. I was thinking maybe we could "help the breed". The last 7 posts should have been handled differently, maybe "PM"????? I don't know or care if this against the forum rules, but I know it is very inconsiderate.
Woops! Sorry! Did not mean to get side tracked.
Tell you what - once my motor is out, disassembled and components get worked on, etc, etc, etc, I will share my experience of 380 build.
My apologies!
Old 09-26-2013   #33
secondchance
Originally Posted by Scrrem View Post
I'm getting ready to go the 380 route with an offset grind. Does the grinding process dislodge the plug in the crank??
Rich
No - according to Ryan. I will still inspect the plug and make sure all is well before my mechanic starts closing up.
Hmmm, according to GC it's otherwise... I will look into it further.
Old 09-26-2013   #34
You've been advised.
Old 09-26-2013   #35
secondchance
And noted Redeye!
I will inspect the plug and turn to Dr. Phil for guidance.
Thanks.
Old 09-26-2013   #36
5ABI VT
Awesome info Hopefully Ill be treading down this path in the relatively near future.
What options are there for cams? are custom grinds available? Im tempted to want to do something like my LT4 build.. all lightweight, maxilite rods, hollow valves , solid roller etc.
Im thinking offset grind, longer rod, aggressive cams, hollow valves, solid lifter setup and rpm it a bit more for more hp. Not sure how the lifter setup is on the LT5. The s54 in my e46 M3 had a rocker setup that was easy to maintain lash with via swapping shims.
Old 09-27-2013   #37
alnukem
GC, Thanks
Does anybody have any Torque numbers from one of these?
Old 09-27-2013   #38
alnukem
My apologies!
No Problem! Was you planning on doing it over the winter?
Old 09-27-2013   #39
secondchance
I think SGC and Pete grinds Stage 1, 2 and 3(?). These are stock cams ground down on the opposite side of the lift lobe (?).
Now that I have more time due to delay I am seriously considering Stage 1, intake.
Old 09-27-2013   #40
I think the question to ask yourself is , what power level do you want to get to? Again, you may be comparing apples to oranges looking towards the LT4 as a guide. Achievable power with few and simple mods to LT5 is rather impressive. No rockers in LT5, tappets directly actuated by cam lobes.
500+chp w just porting through to the heads, stock cams, headers and exhaust
550chp doable w stock displacement and bottom end. Add Pete cams.
Look at tpepmeir's 427 build for 700+chp and lots of choices in between and up to 441CID.
Tags
3.775, 380, cams, sleeves, stroker
