09-06-2013 | #31 | |||
Re: engine wear
That is extremely good news...but does not explain what you seen on dipstick and in oil you drained quite yet unless that is the "Overly Dramatic" Part Quote:
But then again...you did say your oil pan bolts had dropped out....almost half of the fourteen 8mm bolts Last edited by Dynomite; 09-06-2013 at 08:22 PM. |
09-06-2013 | #32 |
Re: engine wear
So it sounds like the engine got low on oil and the lifters got noisy. Should be ok.
My earlier comment about looking at dirty motor oil in good light still holds- there's all kinds of micro particles that may or may not mean anything. |
09-06-2013 | #33 |
Re: engine wear
Got the pan out and well there's nothing unusual. Just a lot of dirt. Between the heat shields, jacking the motor up and everything else I can already see that it's going to be twice as much fun to put it back in the car. So if anyone has tips to get it back in it would be greatly appreciated. And note to self I need to go buy 1/4" swivels
09-07-2013 | #34 | |
Re: engine wear
Jerry's pan gasket for the 90'-92' requires a new "O" ring which is the same diameter but thicker for the oil pick up. Just make sure you keep that "O" ring in place as you position the oil pan with new gasket. I use Blue Loctite on ALL Oil Pan Bolts. Installing New Oil Pan Gasket
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-07-2013 at 12:16 AM. |
09-07-2013 | #35 |
Re: engine wear
hope you get it back together soon. hope to see you out and about
09-07-2013 | #36 |
Re: engine wear
Would you recommend getting two gaskets since its my first time putting the pan back in? In case I mess one up. Also does anyone make a pan bolt kit cuz I just want to put all new pan bolts back in the car. And is there a torque spec for the pan bolts?
09-07-2013 | #37 | ||
Oil Pan Gaskets, Bolts, Oil Level Sensor
On Jerry's page you have the Oil Pan Gasket Installation Guide, Oil Pan Gasket for 90', Oil Pump Suction Pipe "O" Ring. Jerry's Oil Pan Gasket and Associated Typically.......6 mm bolts go 89 in-lbs (three in front of Oil Pan) Typically.......8 mm bolts go 19 ft-lbs (fourteen in rear of Oil Pan) Clean ALL Oil Pan Bolt Holes with cue tip and gas or something similar. Use Blue Loctite (242) on ALL Oil Pan Bolts. As you already know, I use thin coat of Permatex on both sides of the oil pan gasket. The TRICK is balancing that "O" ring in place while keeping the gasket in place at the same time you start and snug up one 8mm bolt on each side of the oil pan. After that.....you are home free Here are the 8mm oil pan bolts (ten) except those two on each side which are studs that hold the exhaust shields. And except the three front 6 mm bolts. Jerry's oil pan bolts You need Four Heat Shield Oil Pan Studs/Bolts You need Four Heat Shield Nuts For your 90' you need Three Oil Pan Front Three 6 mm Bolts Quote:
I am still looking for an LT5 Oil Level Sensor as Jerry does not stock those as far as I can tell
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-07-2013 at 01:11 PM. |
09-07-2013 | #38 |
Re: engine wear
Dynomite aka Mr. Solutions: Thank you for the referral!! I will see if I can find the LT5 Oil Level Sensors!!
90ZR1#1221: Here's a link list for the items you might want to obtain. I don't think there is any need to buy all new bolts, only the ones you need. Front Pan Bolts, 6mm http://jerrysgaskets.com/store2/root...roducts_id=240 Side & Rear Pan Bolts http://jerrysgaskets.com/store2/root...roducts_id=304 Pan Studs http://jerrysgaskets.com/store2/root...roducts_id=303 Loctite 243 for Pan Bolts (Exterior) & Pan Baffle Bolts (interior) http://jerrysgaskets.com/store2/root...roducts_id=591 Pan Gasket with Seal http://jerrysgaskets.com/store2/root...products_id=16 Cleaner for gasket surfaces, tapped bolt holes, bolts and general purpose cleaner. http://www.autozone.com/autozone/acc...er=119712_0_0_ Oil Pan Gasket Installation Guide http://jerrysgaskets.com/store2/root...roducts_id=732
09-07-2013 | #39 | |
Re: engine wear
The torque specs are on page 6A2-88. Oil Pan to Crankcase Bolt is 20ft/lb.
09-07-2013 | #40 | |
Oil Level Sensors
Jerry my man.......those were Left Clickable Links in RED I call them Descriptive Links.
Anything underlined and especially in Bold Red is left Clickable That is my story and I am sticking to it. Oh...and I might add....when you buy from Jerry expect the most professional Packaging of Gaskets and expect two day delivery...Maybe three day if post lady is lazy. And that Post above is referenced in Solutions under the Heading ENGINE LUBRICATION SYSTEM New Oil Pan Gasket and Bolts Quote:
The Oil Pan for 1990, 91 & 92 are interchangable with the only difference being, the 1990 LT5 engine was not equipped with a Low Oil Level Sensor. The extra material was cast into the pan but not machined for the screw-in sensor. As such, the oil level indicator would not be functional if the 1990 oil pan is used for 1991 & 1992 applications First two photos are of a Brass Oil Level Sensor threaded Connecter and the last three photos are of a Plastic Oil Level Sensor threaded Connector. Brass Oil Level Sensor 93'-95' Jerrys Brass Oil Level Sensor 93' to 95' Plastic oil Level Sensor 91'-92' Summit Racing Oil Level Sensor Jerrys Plastic Oil Level Sensor I learn something every day Jerry.....there is an identical Solutions on two web sites just for your information and both updated continuously
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-14-2017 at 02:01 PM. |
