Old 07-24-2013   #31
CJ_ZR1
Default Re: Finally completed coilover and sway bar install, plus Christmas came early
Originally Posted by 5ABI VT View Post
Car looks awesome !! I'm curious .. What kind of an airbox is that I see on a few zr1s? Looks aluminum/metal ??
It's a hand made stainless steel air box made very similar to the Marc Copland Air Box. I had it powder coated to match motor.
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
Old 07-25-2013   #32
carter200
carter200's Avatar
Originally Posted by CJ_ZR1 View Post
Shock width is 50.28mm
With snap ring total width increases to 53.28mm
The ring is roughly 3mm thick and the grove in the shock body is cut 1.5mm deep. The ring is also roughly 1.46mm thick.
Hope this helps
Great info and thanks. If anyone needs their shocks cut I can do them. The first person that send me their shocks to do and provides the snal ring, too I'll do for $80 shipped. The normal price is $88 shipped.
PM me if interested...............thanks, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
