03-21-2013 | #31 | |
Re: AC Vacuum Pump and Oil
Joe 1990 Bright Red ZR-1 #2599 |
03-21-2013 | #32 |
Whoops, pages out of order. sorry.
03-21-2013 | #33 | |
I took my 609 Cert 2 years ago.. It is also open book at least when I took it.. fairly easy test to take
03-21-2013 | #34 |
Joe.....you are DAMAN.....thanks....I shall study this. Appreciate the photo copies
I am looking for that 25 amp A/C fuse on main fuse block? I have no voltage at the pressure cycling switch so I hot wired the compressor clutch which engaged fine. Cliff
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-21-2013 at 06:49 PM. |
03-22-2013 | #35 |
YW. If you need the fuse block details, let me know.
03-22-2013 | #36 |
Ya...where is that A/C 25 amp fuse?
Or maybe I should ask were is that Main Fuse Block |
03-22-2013 | #37 | |
Sad I know that without looking
03-22-2013 | #38 |
Hi: That is NOT sad......That is Happy
So where is that fuse block on the car and is there a 25 amp A/C Fuse in that block? I am presently looking at the A/C Clutch Relay (VetteVet on the phone explaining it is second relay to right of steering Column) I am checking to make sure I have HOT at the relay with engine running. And then Hot after the relay. I have no voltage at the 10 amp A/C fuse on right passenger fuse panel. No voltage at A/C High Pressure Cut out switch or A/C Pressure Cycling switch. This all happened when I was poking around with a hot wire and you know how that goes I am soooooo close...... Cliff
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-22-2013 at 08:22 PM. |
03-22-2013 | #39 | |
I am not where I can look at the 8A manual or the car.
but if memory serves the fuses are labeled. Quote:
03-22-2013 | #40 |
Here's the fuse block on the passenger side. The 2 fuses are 15A CTSY fuse and 25A A/C fuse. The clutch relay should be fed from 25A. Not sure why you have a 10A for CTSY (if that's what you're talking about).
Joe 1990 Bright Red ZR-1 #2599 Last edited by vilant; 03-22-2013 at 09:23 PM. |
