Old 02-28-2013   #31
Kevin
Kevin's Avatar
Default Re: Anyone care to guess...
Originally Posted by VetteVet View Post
Dom,
They are not GM. They are from a high horsepower, high revving 5.3L V8. I'm not going to say any more at this time.
They are 3 pins. BAT+, GND and trigger. Trigger high to start dwell period, trigger low to cut primary current and fire the coil. I have a scope so I can get data on dwell as installed in the OEM application. This data can be used to populate the cells in the LS1 PCM coil dwell table.
Jep
gt500?
Old 02-28-2013   #32
VetteVet
VetteVet's Avatar
Originally Posted by Kevin View Post
gt500?
They're from an outboard, believe it or not.
Damn, the "French model" commercial just came on again.
Jep
Old 04-23-2013   #33
Hey JEp,
how is the ECM swap/conversion coming along?
Old 04-24-2013   #34
Funracer
After reading this thread I realize I am truly a Z idiot.
A Zidiot?
You men keep up the good work.
Funracer is offline   Reply With Quote
Old 04-24-2013   #35
Jep,
I thought all the LSx coils were 4 wire. Did you chose the 3 wire due to form factor? Is the 411 going to support a 3 wire setup? Sounds like you and Scott may have some collaborating to do.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-23-2013   #36
VetteVet
VetteVet's Avatar
Sorry for not posting any updates on this project. I went for quite a stretch there working 7 days a week and in the evenings as well. In addition to my day job, I was getting the offshore boat and two tunnel boats ready for racing season. Now that most of the racing stuff is done, I can get back to the forum and have at least some time to devote to the PCM project.
I'll post up all of the latest info within a day or two.
Thanks for the patience.
Jep
Old 05-23-2013   #37
Jep,
Any chance u could provide disassembly of ALDL? Be worthwhile to be able to output params that currently are not.
Old 05-23-2013   #38
VetteVet
VetteVet's Avatar
Jep,
Dom,
That one is easy to do. There is an ALDL data stream table. Each entry is the memory address where the value to be output is stored. The table is arranged from the first ALDL output word to the last. It just requires identifying what parameter you don't need, finding it's location in the table and then substituting the address of the data that you want to output in it's place. Once that's done, modify the data stream definition file for whatever scanner software that you are using (I use TunerPro) to reflect the name of the new parameter and specify units and scaling.
What year is your Black Rose? I can get you the table location if you need it.
Jep
Old 05-23-2013   #39
92. I'm using the $D0A mask
Old 05-23-2013   #40
VetteVet
VetteVet's Avatar
Dom,
Look at address 08BB (if viewing an unstacked BIN file) or 88BB (if viewing a stacked one). You should see 80 00 80 01. These values correspond to the addresses of the PROM ID MSB and LSB, which is the addresses where the PROM ID is stored. Each additional pair of bytes will correspond to the memory address where the next data stream item is stored in memory.
Assuming that you are using the BPPA binary, the following table lists the address that the ECM retrieves the value from(column 1), the position in the data stream(column 2) and the description of the data item(column 3). If you view the values starting at 08BB(or 88BB), you should see the values in column 1(assuming that I didn't make any mistakes typing them in).
8000 01 PROMIDA PROMID (MSB)
8001 02 PROMIDA+1 PROMID (LSB)
0003 03 MALFFLG1 MALF FLAG WORD 1
0004 04 MALFFLG2 MALF FLAG WORD 2
0005 05 MALFFLG3 MALF FLAG WORD 3
0006 06 MALFFLG4 MALF FLAG WORD 4
0007 07 MALFFLG5 MALF FLAG WORD 5
0001 08 NVMW1 NON - VOLATILE MODE WORD
0002 09 NVMW2 NON - VOLATILE MODE WORD
0067 10 CARSMW MODE WORD FOR COMPUTER AIDED RATIO SELECTION LOGIC
0048 11 FMDBYTE 1 FMD BYTE 1 MODE WORD
0049 12 FMDBYTE 2 FMD BYTE 2 MODE WORD
004D 13 MW1 MINOR LOOP MODE WORD 1
004E 14 MW2 MINOR LOOP MODE WORD 2
004F 15 MW3 MINOR LOOP MODE WORD 3
0052 16 LCCPMW LCC & CCP MODE WORD
0054 17 CLCCMW MAJOR LOOP MODE WORD
0055 18 AIRMW MAJOR LOOP MODE WORD
005D 19 MWFA1 FUEL AIR MODE WORD
015D 20 PPSW PPSW VOLTAGE A/D COUNTS
01CE 21 NVRATIO RATIO OF ENGINE SPEED TO VEHICLE SPEED
0158 22 COOLDEGA COOLANT TEMPERATURE
0106 23 ADMAPND MANIFOLD ABSOLUTE PRESSURE (NOT DEFAULTED)
011A 24 ADTHROT THROTTLE POSITION, A/D COUNTS
015C 25 ADBAT BATTERY VOLTAGE, A/D COUNTS
0184 26 ADOILTMP A/D COUNTS FROM OIL TEMPERATURE SENSOR
0117 27 ADPTVAC PORT THROTTLE ACTIVATION VACUUM (FOR M61)
01C4 28 ADMAT MANIFOLD ABSOLUTE TEMPERATURE A/D COUNTS
011F 29 LADO2 A/D COUNTS FROM LEFT HAND O2 SENSOR
0120 30 RADO2 A/D COUNTS FROM RIGHT HAND O2 SENSOR
0103 31 LBLM LEFT BANK BLOCK LEARN MULTIPLIER
0104 32 RBLM RIGHT BANK BLOCK LEARN MULTIPLIER
0148 33 BLMCELL BLOCK LEARN MULTIPLIER CELL NUMBER
0138 34 LALDLCNT LEFT O2 SENSOR TRANSITION COUNTER
0137 35 RALDLCNT RIGHT O2 SENSOR TRANSITION COUNTER
00FD 36 LINT INTEGRATOR VALUE FOR LEFT O2 SENSOR
00FB 37 RINT INTEGRATOR VALUE FOR RIGHT O2 SENSOR
85AD 38 KSECINJ `MULT' SECONDARY INJECTOR ON FUEL SCALAR
01A0 39 PURGEDC CANISTER PURGE DUTY CYCLE
0035 40 ISSPMP IAC PRESENT MOTOR POSITION
00E3 41 ISESDD DESIRED IDLE SPEED
30C8 42 NEWRFPER TIME BETWEEN REFERENCE PULSES (MSB)
30C9 43 NEWRFPER+1 TIME BETWEEN REFERENCE PULSES (LSB)
30D0 44 SEREF UNLIMITED SPARK ADVANCE REL. TO REF. PULSES (MSB)
30D1 45 SEREF+1 UNLIMITED SPARK ADVANCE REL. TO REF. PULSES (LSB)
00F6 46 NTRPMX ENGINE SPEED
3013 47 TIME ENGINE RUNNING TIME IN SECONDS (MSB)
3014 48 TIME+1 ENGINE RUNNING TIME IN SECONDS (LSB)
00DA 49 NOCKRTD ESC KNOCK RETARD
30D7 50 OLDPA3 ECU PA3 COUNTER VALUE FROM LAST MINOR LOOP (MSB)
30D8 51 OLDPA3+1 NOT USED
0149 52 FILTMPH FILTERED MPH
0118 53 NTPSLD THROTTLE POSITION LOAD AXIS VARIABLE
00A1 54 CUREFIAP CURRENT INJECTOR 'A ' FUEL PULSE WIDTH
00A3 55 CUREFIBP CURRENT INJECTOR 'B ' FUEL PULSE WIDTH
3089 56 LBPINJC LEFT HAND LOW VOLTAGE CORRECTED BPW
308A 57 LBPINJC+1 LEFT HAND LOW VOLTAGE CORRECTED BPW
3099 58 RBPINJC RIGHT HAND LOW VOLTAGE CORRECTED BPW
309A 59 RBPINJC+1 RIGHT HAND LOW VOLTAGE CORRECTED BPW
307D 60 BPINJSD BASE BPW WITH D - TPS A.E. FACTOR APPLIED
307E 61 BPINJSD+1 BASE BPW WITH D - TPS A.E. FACTOR APPLIED
01A4 62 EGRDC EGR DUTY CYCLE
0060 63 FANMW FAN CONTROL MODE WORD
Hope that helps.
Jep
