08-16-2013 | #31 |
Re: Alternator Problems
I had forgotten that I did not use all the parts in the kit.
Did not use the regulator nor diodes. The life of such components is measured in 100s of years. There are those that maintain a "quality" rebuild requires such be replaced. I don't. Proof so far is that my alternator is still working after a decade. As far as the bearings go? Well a decade is not bad for a package that has more than one language on it. Oh well, you mileage may vary. Just make sure to inspect them (spin them) before installing no matter what supposed quality you think you're buying. It's really not hard to fix these alternators.
08-16-2013 | #32 | |
I've since moved to a new state and started a new job. In the mean time the Z has just sat. Now I have time to get things right, and the alternator is back out of the car. None of the local shops around here rebuilds alternators, nor do they know anyone who does. They all just purchase new ones. After taking the alternator down to the parts store for a free test on their bench, I know a minimum the bearings are bad (squealed loudly!). They gave me a print out of a bunch of numbers, but I don't know how to interpret them. Given that, I figured I would take it apart and start replacing things. Sounds silly, but that's what I'm left with. |
08-17-2013 | #33 | ||
Go for it. With the videos given and the link to the ZR-1 page you should be fine. As you may know our Alternator has a higher current output than the standard Alternator of the period. ALSO it has a mounting hole on the back shell that other alternators do not have. Keep your original alt. They are not easily found and when you do you may get one WITHOUT the mounting hole !!!
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 08-17-2013 at 08:17 AM. |
