Old 07-15-2006   #31
8upZR1
8upZR1's Avatar
Default Re: Ignition module ground
This probably does not belong in this post, but I was looking on Ebay for ZR1 engines and found an 89 MY engine with drivetrain and front clip. The date stamp is 88. I noticed the PCV system is different than on my car. I was wondering how similar this motor is compared to my motor and if the rated power output was different. The starting bid is 11K, a bit high IMO but if this motor has some sort of additional collector value since it is an 88 then maybe the price is right.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!!
8upZR1 is offline   Reply With Quote
Old 07-20-2006   #32
ShawnZR-1
ShawnZR-1's Avatar
I have read through this thread with a bit of dispair since I'm currently rebuilding my top end. I pray that I don't run into the problems you have but I have been guided by Mike at EES so I feel quite confident.
In any case, I would be very willing to spend some time with you (ROAD TRIP!) troubleshooting your beast once mine is back on the road. Don't give up on it, but certainly take a break from it. Only bad things come from frustration.
Just know we're out here to back you up. I'm not an expert by any means, but I have a decent troubleshooting mind and have a knack for looking at things from different perspectives. We can and will get your Z back in tip top shape!!!!
1991 Chevrolet Corvette ZR-1
ShawnZR-1 is offline   Reply With Quote
Old 08-02-2006   #33
Tilbac
Default
Good news
Tilbac is offline   Reply With Quote
Old 08-03-2006   #34
8upZR1
8upZR1's Avatar
I have finally had a day of free time and have disassembled the LT5 once again. It gets remarkably easier every time. Anyway I have found the culprit. A true mystery, now solved. I dunno how or when it happened. I cant imagine that I did not notice this the last time I assembled the motor. But here it is.....the F F F F'ing hydraulic followers. 17 of the 32 are locked in a fully extended position. I have put a few in a vice and tried to collapse them, but no luck. They will not budge, not even for a hammer. They are somehow solid, and fully extended. I imagin that most or all of them were on the intake side. I did not pay attention due to some extraordinary circumstances. Normally I would label where they come from but I was interrupted, I then turned the head on its back and they all fell out before my brain could think about it. Oh well, but since I had combustion in the intake manifold I assume that most are from the intake and they held the valves open even when riding on the base circle of the cam. How this happened, I do not know. If a piston hit them I would think that they would be stuck in the retracted position. I remember checking them before I put the motor back the first time and they were fine. I always kept them in a zip lock bag with oil.
So, my question to everyone is this: Does anyone have a set of lifters for sale? Does anyone know specifics about what type of audi lifter will work? I have heard A8 but what year? Intake or Exhaust? Does anyone know what has gone wrong with my set?
Old 08-06-2006   #35
8upZR1
8upZR1's Avatar
After consulting with a santeria priestess named Pearla, I have found a solution to my broken lifters. I soaked them in the urine of a virgin overnight and left them in a room full of pennies with silver pieces at the corners.....and what do ya know, they actually do move now. And to think that women dont have a clue. Anyway, the heads are back on and hopefully today will be the last time I need to work on this thing. I will post results.
Old 08-08-2006   #36
I remember a thread somewhere, here or at CF or CAC, about lifters. Someone determined that the lifters from the Aurora motor were the same size lifter bore. I don't know if this is of any use to your situation.
Good luck with the motor!
