View Poll Results: Does your state require emissions testing on rollers?
Yes 26 48.15%
No 27 50.00%
Don't know 1 1.85%
Voters: 54. You may not vote on this poll
Old 10-11-2012   #31
GipperND
Default Re: Emissions Testing
I have to do my first CA emissions testing in the next two weeks. Is there a consensus on whether it's better to test with the car in full power or not?
GipperND is offline   Reply With Quote
Old 10-11-2012   #32
mike100
They won't ever reach a throttle position high enough to tip into the secondaries anyhow. Mine passes with it in either position.
Old 10-12-2012   #33
GipperND
Thanks for the response. My '98 Corolla barely passed last time so I'm a little nervous about the ZR-1. Fingers crossed.
Old 10-12-2012   #34
gbmidyear66
The bad news....we have full emissions test here... gas cap, idle test and dyno test.
The good news.... with new injectors, plugs and no vacuum leaks - the Z passed with flying colours, AND they are eliminating vehicle tests here end 2014 (very few cars are failing) and will focus on heavy industrial vehicles only
gbmidyear66 is offline   Reply With Quote
Old 01-04-2013   #35
USAFPILOT
USAFPILOT's Avatar
What happens in TX if you drive to an area they dont do the sniff test? Do you need proof you live out there?
Old 01-04-2013   #36
mike100
The last time my car smogged real clean was 10 years ago, but after replacing the O2 sensors, the NOx really came down this time and it runs clean again. The fuel mixture band for the formation of the fewest oxides of nitrogen is so narrow and it does require accurate 02 readings. I was surprised that the sensors foul with age more than mileage (20-30k miles on the somewhat more dirty tests).
Old 01-04-2013   #37
Fully Vetted
Fully Vetted's Avatar
The county the car is registered in determines the testing procedure. So, to answer your question..yes. To go to a nontesting county the car has to be registered there.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
