06-02-2016 | #31 |
Re: Rear End Lock
This very thing just happened to one of our forum members as he was driving his car home from Haibecks. It is the transmission. His car only can move in reverse. Will need a new tranny or a rebuild. He had 4.10's and was going at a good clip also for an extended period of time. fyi..
ed ramos #3028 |
06-03-2016 | #32 |
Re: Rear End Lock
This is a little unnerving to read. I take my car on extended trips all the time and can't imagine the idea of a lockup at 80mph. I'm doing a little more maintenance this weekend and I think I'm adding a transmission oil change to the list.
06-03-2016 | #33 |
Re: Rear End Lock
There is nothing like a ZF after Bill does his magic !
06-03-2016 | #34 | |
Re: Rear End Lock
Since this one is apparently disassembled it might be wise to accumulate some images of the damage. Exploded/damaged parts should easily be identified in a ZF image by part # or even the item # in the ZF portion of the FSM. Last edited by WVZR-1; 06-03-2016 at 10:10 AM. |
06-03-2016 | #35 |
Re: Rear End Lock
06-03-2016 | #36 |
Re: Rear End Lock
Bill B did my trans 50k ago, lots of 1/4 mile, 1 mile, 1.5 mile and road course runs, still great
06-07-2016 | #37 |
Re: Rear End Lock
Get some ...actually 2.2 quarts.
"It's 10:00pm...do you know where your trannys are?" |
06-07-2016 | #38 |
Re: Rear End Lock
When I bought my 93 LT1 car this happened to me as well. 3 days after buying it . I did however spend the first 2 days trying to hit 300km/hr and I needed to use 6th because of the 4.10 gears.
06-07-2016 | #39 |
Re: Rear End Lock
My lockup was a "blue-tag" ZF in my std 95 LT1 Vette. Has anyone had this problem with the older square-tooth xmissions, and mabye the 1990s specifically??
06-07-2016 | #40 |
Re: Rear End Lock
Mine was a 93 black tag. I've since never used 6th for anything but the lightest throttle for freeway cruising. I even dropped my rear gears to 3.73s in my 93 with its 8000rpm lt4 stroker I built so I wouldn't ever need 6th and since the trans is essentially a 5 speed anyways it works out as 5th tops out way too high anyways.
