Old 09-30-2012   #31
Default Re: clutch engagement; early
Changed the master, now the car will not disengage the clutch at all....
Old 09-30-2012   #32
Changed the master, now the car will not disengate the clutch at all....
Did you bench bleed the master?
Any thought on clutch fork?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-01-2012   #33
scottfab
scottfab's Avatar
Does the peddle fell soft?
Then you have air.
Else look for a bent clutch fork.
Scott
Old 07-16-2013   #34
POWERBRAKEBOB
The clutch master is only 11/16' piston size. The slave is 1 1/16" the small master doesn't have enough volume to operate the clutch slave with enough volume. I'm working on a larger bore master, and slave seal kit mto make it easier to shift.
POWERBRAKEBOB is offline   Reply With Quote
