#31 |
On the crankcase vent, I would suggest using the material Marc H has rather than scotchbrite. I went thru this last year. CC was pressurizing at WOT. I was getting a slight pooling of oil at the cam cover bolt head adjacent to the vent tube boss. Also, oil on oil pan stud at front corner of pan on passenger side.
#32 |
I dont remeber,..but the material was pretty brittle.....in theroy,..could I not put that material into the hoses from the vent and accomplish the same thing?
#33 | |
![]() Join Date: Feb 2009
Rich
#34 |
well I dont think I want to go pulling off my cam covers just to check,..If its just to screen out oil from fumes to the airhorn,..I wonder if I could put material at the holes entrance.
#35 | |
![]() Join Date: Dec 2003
Pete
#36 |
pete,..which filters and where?
#37 |
![]() Join Date: Dec 2004
I'm not sure but I think Pete had this product in mind.
![]() http://www.jegs.com/i/K%26amp%3BN/599/62-1300/10002/-1 I was thinking I might try two of these someday myself, and see what happens. ![]() Tom
#38 |
After further thought....I figure that I was looking at the wrong stuff!
![]() I would buy two of these, take Marc's stuff and use it in place of the filter material that comes with these fuel filters. http://www.jegs.com/i/Spectre/865/2369/10002/-1 ![]() Tom
#39 |
Guys!...great ideas,..but..where from the outlet of the cam cover to the airhorn are they going to fit??...I know from experience you cant even put a red/blue fitting on the cam cover outlet because of the clearance.
Purolator has material that designed for this(oil/air breathing),..its just a matter of putting it inline that is clean and unobtrusive... still working on the pcv/idle issue,..should have that ironed out today,..i am going to design something cool... AND I got my oil catch can! With that said,...I am humbled by the knowledge and the sheer willingness to help us in need,..and it really flows both ways,... ![]() ![]() |
