Old 02-02-2012   #31
Polo-1
Default Re: Finally Heads are Done
with Pete's cams.....
490/430-35 rwhp/rwtq.
Old 02-03-2012   #32
I get no gear rattle in cruise, and idle can be mitigated with proper tuning.
If it gets louder at idle, its after a long run when trans fluid is hot. Also using the right trans fluid helps.
I use the BMW Castrol 10W-60.
I agree w/ Dom (and don't think that doesn't worry me! )
That said, speaking of trans rattle, it wasn't always so. After the "500" package was complete, including the Fidanza, Marc upped the idle to 750 rpm. That helped. But, the biggest bang was the new injectors (Accels) (My injectors had been replaced at the time I bought the car, but apparently with NOS (aka same ol sh*t) injectors. It didn't show up until Marc was putting the tune on the new mods, except for the rattle - that I figured was "normal" for a Fidanza. Not so! ) Oh, and I run the Castrol synthetic as well. The combo of idle, injectors operating at 100%, and trans oil (especially when it's cold) and there's NO rattle.
Y'all be the judge: Here's mine idling on a cold (windy) day. Granted it is running stock cams - i.e., Pete's cams might be a bit differerent, I'm guessing.
Check it out!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-03-2012   #33
PAUL THAT IS GREAT I DO NOT HEAR ANY RATTLE AT ALL
Old 02-03-2012   #34
Tuned to perfection
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 02-03-2012   #35
Ok fellers on the topic of Fidanza
Should I or Not?
Old 02-03-2012   #36
I don't notice it, its probably only audible to those sissies that also need 10 layers of quiet mat and exhaust mods to silence "the drone"
Go buy a damn Prius if you want quiet.....
Lee drone vs exhaust note are two seperate animals. Corsa solved the drone issue for our cars. When I replace my carpet the Dynamat is going in as well its just a smart mod.
As to a Prius, Not in my lifetime lol
Old 02-03-2012   #37
Should I or Not?
Stocker hold's good to 540-550 rwhp. I don't like the Fidanza. But then again I don't like Corsa either. I like redheads....... it's just one of those thing's D. Save your money and install a stocker.
Frank Urbo.
Old 02-03-2012   #38
I have the ability to block out my wifes nagging drone.....try harnessing the same power...
Old 02-03-2012   #39
You could make a fortune !
Frank Urbo.
Old 02-03-2012   #40
Corsa kills two birds ... DRONE & EXHAUST NOTE!! (Makes an LT5 SOUND like a Prius!)
JK...
P.
90 #1202
Sans secondaries
