Old 02-05-2012   #31
VetteMed
Default Re: Risk of ignoring lifter noise?
Got the driver's side cam cover pulled (the noise was most prominent in this area). I really don't think anything "looks" any different from about 7k miles ago, which was the last time the cam covers were off, prior this noise developing.
There is some scoring on the bearing surfaces of the cam cover, but I don't know how much of that is normal wear.
Is there any way to determine which lifter(s) are bad, if any? I notice that when the cams are positioned such that the valves are closed, the lifters are able to spin / rotate, is this normal?
The wear strip on the LH chain guide is broken, but it does not appear any worse than 7k miles ago.
The edges of some of the timing chain links appear "polished", but I figure that's normal wear.
SO, where do I go from here?
Thanks,
Andrew
Old 02-05-2012   #32
VetteMed
I suppose there's no sense in prolonging the inevitable here... I am going to plan to pull the motor out. I can now see that my diagnostic options are limited without actually holding any (defective) components in my hands. I guess this officially ends the "how far will my motor go without internal problems" question. The answer: just shy of 195K miles.
Old 02-06-2012   #33
Pete
Pete's Avatar
Thanks,
Andrew
Yes,on the lifter rotate
Yes,on the polished chain
If there was work done to the motor recently and before you yank the motor,i would look into the chain tensioner,tensioner is like a lifter.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-06-2012   #34
VetteMed
Would the tensioner potentially cause the on-and-off oscillating type noise that I described?
Is there any way to diagnose a bad tensioner once it's removed?
Old 02-06-2012   #35
Pete
Pete's Avatar
Once you take it out it should release all the way out and should be able to take it apart into two pieces if not then it's stuck and no good.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-06-2012   #36
VetteMed
Pete
OK, thanks Pete. I removed the LH tensioner earlier this evening, and it does in fact release and separate into two pieces. there's some scuffing along the surface where the tensioner contacts the guide, but it appears normal otherwise.
I am going to pull the RH tensioner tomorrow.
Is there a third tensioner for the main chain?
Old 02-06-2012   #37
Pete
Pete's Avatar
There is a third one but that one is basicly fixed.
Just make sure you reload the tensioners the right way before reinstalling them.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
