12-09-2011 | #31 |
Re: X-Brace
I've seen Jeff's brace and it looks like it tucks up alongside the frame rail. The only issue I saw was interference for a jack on the jacking points.
12-09-2011 | #32 |
Re: X-Brace
Must be the angle of the pic. It looks low. I want it but my enlonged Speed humps would eat is because they are enlongated. How long did it take to install?
12-09-2011 | #33 | |
Re: X-Brace
The problem i see with Jeff's frame brackets is they have rod ends which move/rotate frame connectors are suppose to be solid not swivel. I'm thinking this is the reason why he ran out of jack before the wheels got off the ground. I'm sure a few more pumps the wheels would be off the ground but with enough pumps you'd be able to get jello off the ground. Just my thoughts. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 12-09-2011 at 01:39 PM. |
12-09-2011 | #34 |
Re: X-Brace
doesn't look too low for me a the stock ride height.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
12-09-2011 | #35 |
Re: X-Brace
Im stock height as well. Normal driving no issue but my issue is the wide enlongated speed humps in my gated community that almost high center my ride at any angle
12-09-2011 | #36 | |
Re: X-Brace
Also with the Heim joints that Pete is referring to they tend to get dirt/Grit in them and can squeek like a MOFO. When I replaced my trailing arms with the Banski trailing arms they offer a new boot kit for these joints to help keep out the dirt and grit out of the Heim Joints. If I was to install this brace the the boot cover for the joints would be a must. Trust me. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-09-2011 at 02:02 PM. |
12-09-2011 | #37 |
Re: X-Brace
well the brace isn't supposed to move around right...if it is fixed in one position it shouldn't make any noise.
12-09-2011 | #38 |
Re: X-Brace
Not with Heim joints. Its designed to move like Pete was stating.
12-09-2011 | #39 |
Re: X-Brace
if it can move then can't the chassis still flex?
12-09-2011 | #40 |
Re: X-Brace
A little bit yes
