Old 11-12-2011   #31
jrd1990zr1
jrd1990zr1's Avatar
Default Re: New 90 ZR1 Owner
Originally Posted by Socalerv View Post
Would you change out the injectors yourself or pay the bucks and have it done?
Did mine myself with advice from the brotherhood. Not hard to do
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 11-13-2011   #32
sammy
where in texas are you located ????/ if your close to katy/houston we could put you in touch with rick hipsher . or if you are somewhat close to new braunfels there is corey henderson who has a shop that could do the work for you . he is one of the best lt5 mechanics in the world . he also doesnt charge an arm and a leg .henderson performance tech.
Old 11-13-2011   #33
Socalerv
I have spoken with Rick a couple of times in the past. Hope I can convince him to be a mentor when the arm heals as the plenum is coming off, change out injectors, check the vacuum, check the coils, ect.
Here is my material and tool list, am I missing any thing?
I will use Viton over Buna here is my short list of the items needed to replace the injectors.
http://jerrysgaskets.com/store2/root...&products_id=7
Plenum gasket $23.50
Part #10168684
http://jerrysgaskets.com/store2/root...roducts_id=384
Fuel Injector Seal Kit Lwr Primary VITON - Part#10067600 $21.60
http://jerrysgaskets.com/store2/root...roducts_id=387
Seal Set Fuel Feed &Return Block
$4.65 – Part# 14104675V
Spark Plug Wires $74.25 Part# 12073977
Permabond A136 $37.00 – Part# PB136
AND.... here is a tech data link for info to replace the lower primary injector seal. You can download this to your computer and/or print it out to refer to while you are working.
http://jerrysgaskets.com/store2/root...roducts_id=446
Spark Plugs AC 41-602 gapped at .035 $2.25 a piece
Injectors
http://fuelinjectorconnection.com/sh...&productId=208
Part# ZR1oemla $669.00
Socalerv is offline   Reply With Quote
