#31 | ||||
![]() Join Date: Dec 2003
Thanks for your constructive input.
#32 |
![]() Join Date: Mar 2004
Gentlmen.... can we have a cooling off preiod ? Period
![]() Thank you. |
#33 |
I may have gotten ahead of myself. I was trying to stay agnostic to the final implementation, but in my head I picture something akin to a wiki, where members can modify the articles as they notice it has "aged" or gotten out of date with more current info/discoveries.
But if that's not the case, if editing/posting the articles would be centralized, the current method of authentication used for the Registry site member's area is no worse than the current scenario. I don't know what would differentiate this new effort from the "Maintenance" section of the registry site. I'm sure that info was all great when first put out, but the value falls off as time passes and no one updates it. I'm not saying that will happen, more asking what would differentiate this from past efforts? Unrelated, I'd also toss out that what might be an easier/quicker win would be to take the many technical articles from the HotB newsletter and post them in a searchable/indexed article format. There is a lot of stuff in those newsletters, but it is hard to find it if you don't know exactly what article and issue you are looking for. |
#34 | ||||
Bob,
I still think we are thinking along the same lines. It doesn't really matter where the origin of a particular tech subject comes from. Considering the legitimate suggestions in this thread, I will attempt to summarize. Purpose: 1. Establish an easy to use index of maintenance procedures with major topic sections & sub-topics. Example:I. LT5 Engine A. Specifications 1. Clearances 2. Sealants & Adhesives 3. etc. B. Mechanical Maintenance [Minor] 1. Secondary Port Throttle 2. Fuel Injectors 3. Starter 4. etc C. Mechanical Maintenance [Major] 1. Engine Removal 2. Camshaft R&R 3. Cylinder Head R&R 6. etc II. CLutch & Transmission III. Driveline & Differential IV. Suspension V. Brakes etc. 2. Establish a standard format (photos, captions, order, etc., for each article. Only one article per subject. 3. Edit existing maintenance articles on the Registry Forum. Add articles as needed, by creating from scratch, forum threads and all other useful resources. The foregoing is just a rough outline of a possible starting point. Quote:
It is a big job, but not something that must be done all at once. It is part of the facelift needed on the Registry website and would be an advancement of accuracy & simplicity.
#35 |
![]() Join Date: Oct 2010
Jerry, I like your outline but anything outside of stock maintenance would be subjective it would have to be generalized or based off of proven methods. Everyone would have an opion on which spark plug or oil is best. That is what is wrong with "wiki". So more than one article per subject may have to be written. Some people think you should use one sealant vs another.
#36 |
![]() Join Date: Jul 2004
A wiki does not necessarily mean open access to editing. They can be set up to give varying levels to allow only 'authorized' accounts the ability to edit. This can avoid the 'clutter' normally associated with forum posts. You can also set them up so that any changes have to be authorized explicitly by the wiki admin (or another account).
On another point entirely, I'd be happy to 'donate' my writing skills, such as they are, to help put articles together and so on. I'm not the most technically knowledgeable, but I can usually manage to throw a few sentences together! ![]()
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#37 |
speaking of wiki's here one that I found very helpful http://straightrazorplace.com/srpwik...zor_Place_Wiki perhaps we could use it as an example if we decide to go that way
#38 |
![]() Join Date: Mar 2010
I like the idea of standardized, authoritative tech data & procedures, beyond what's already in the forum. I also like the idea that the content would be for members only.
I'm pretty junior league when it comes to car tech, but like DaveK, I'd be happy to assist in writing/assembling articles if needed. I'm also a web developer and could help to develop any web applications that might be beneficial. John
1992 #043, Aqua/Gray 40k miles |
#39 |
That's mighty kind of you to offer John
#40 | |
You are correct regarding the subjective nature of plugs, sealants, injector brands, etc. Personally, I never envisioned that type of content in the proposed tech data articles. Specifications for Sealants and Adhesives as exampled, would refer to the same as specified in the Service manual for Loctite & Permabond. Use of alternatives would be best left to personal choice. I am adament about one article per procedure, although some may overlap, such as "Fuel Injector R&R, Coils & Wires R&R and Starter R&R, etc.. I do however, believe each one of those example R&R's should include the complete process and could make use of the applicable section(s) in the others to maintain consistency. Given my Marine history, I'm a "little" OCD about consistency, order & organization. Before any tech articles are written, it may be a good idea to develop a style & format template. Regarding the organization, we might consider a committee to establish the style & format, then prepare a couple of tech articles as examples. Then, Members desiring to help could choose a title from the outline/index and have good examples to follow. The key here would be to not get caught up in pride of authorship so the articles submitted to the committee could be edited if necessary and not offend the author. ![]()
