Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 08-22-2011   #31
Paul in VA
Default Re: WMD for Saturday / Sunday August 20 and 21st
I had a great time both days, wish I could have staed later on Sunday. Jim, David, Phil and I installed a RD Racing cross bar on my car (runs between shoulder belt mounts; reduces body flex). Thank You all!
Ironically, I have an actual lead on my car's ocassional no-start problem. On the way home, I stopped at a Sunoco and filled up. Again no start... plenty of juice. I already solved the VATS issue and replaced the battery. Apparently I have a heat soak issue. I push started the car and it ran fine. At least I now have a direction (and old wiring may also relate to the heavy electrical load with the A/C on). I suspect the wires going from the battery/relay have degraded and when the car is hot, no-start problems. This was really hard to figure out as I don't usually make short trips, or if I do, I am not restarting the car right away. I'll do some more testing...
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 08-22-2011   #32
Wow rough weekend!
Header install Saturday for Yun....
Flywheel / clutch install that took much longer than expected (leaks and issues, but all resolved) Dana 44 (stock 3.45) upgraded to (3.73) for Ricky. Both were sunday and not finished until after 2am!
Lots of other misc items fixed on 3 other cars. I think the rest of WMD's will be scheduled to allow for potential issues.
Jim thanks for hosting!
Great weekend!
Old 08-22-2011   #33
voxdeidave
Talking Re: WMD for Saturday / Sunday August 20 and 21st
To all the WAZOO boys, thanks for all your help!!!!!!
My Z is sooooooooo much quieter at speed and now shifts like budaah! I've really got the itch to do more, now that I've got such a great bunch of guys to back me up. I WILL be back!
Friday for carlise looks questionable for me, but Saturday is carved in stone.......see you then!
Dave
[B][I][SIZE=3]Dave Macbeth[/SIZE][/I][/B]
1991 ZR-1 #384
1969 MGB OD, Pertronix, Monza
1972 MGB project
Life should be filled with classy music and fast cars!
voxdeidave is offline   Reply With Quote
Old 08-23-2011   #34
Jagdpanzer
Jagdpanzer's Avatar
Just felt the earth shake. First thought it was Ricky getting after it with his new gears then I turn on the TV and see it was in fact an earth quake.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-23-2011   #35
QB93Z
QB93Z's Avatar
I hear you Phil, I thought it was the Blue Turtle stomping around.
A careful inspection of the WAZOO WMD facilities has been completed, everything is OK for the next event.
Old 08-23-2011   #36
secondchance
I thought Darrin dropped a ZF6.
Old 08-23-2011   #37
QB93Z
QB93Z's Avatar
Dave
Hi Dave, I bet the new U-joints made a lot of the noise difference. I wonder if the loose clutch spring clip was the cause of the noise we heard on Saturday evening as you were driving on to the lift?
Glad we could help.
Old 08-23-2011   #38
RICKYRJ1
RICKYRJ1's Avatar
Can't thank Phil & Jim enough, they stuck it out with installing my gears
till 2:30 am! Phil gave Jim and I a great education on ther install. Phil made sure my car was 200% correct for my 3.5hr trip home. I arrived at Jim's at 10.00am Sunday and got home 6:30 am Monday. I will give a informed report on the gear swap after Carlisle, I was to tired to evaluate them on the drive home. I'm very proud to call these guys my freinds.
PS. The Blue Turtle cut out at 5 pm
Old 08-24-2011   #39
ZR-1nce removed
ZR-1nce removed's Avatar
tsk,tsk yun. This transmission lift doesn't drop stuff.
90 ZR-1 #0951 Bright Red (sold)
06 Z51 MN6 Velocity Yellow (sold)
2023 C-8 Z51 ELB
ZR-1nce removed is offline   Reply With Quote
Old 08-24-2011   #40
95ZR1#418
95ZR1#418's Avatar
Arrow Re: WMD for Saturday / Sunday August 20 and 21st
Anyone have any thoughts on this hurricane coming & Carlisle?
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
