07-29-2011 | #31 |
Re: New Owner #1581 White/Red
I have a white 91 with gray interior, and Daryll (Goldcylon) has a white 91 with a black interior. Bldavis has a white with saddle interior if I recall correctly.
Andrew
07-29-2011 | #32 |
David, I will be probably tackle this job in the next couple of weeks. I appreciate the recommendations for injectors and gaskets..All this help sure takes the edge off not having to wonder what is available and what isn't.
Jeff, It's hard NOT to be intimidated by that plenum or rather, what's under it. I'm more afraid of breaking something than the actual intricacies of the process. I'm confident that you guys are going to be here when I have questions. Knowing of the zr1net's willingness to share information in this forum influenced my decision to buy a high miler without reservations. Andrew, I guess you already got your answer, but I wondered the same thing.. Apparently not I'm liking this! Part of buying a car that you don't expect and makes the purchase that much more special. very cool....thanks all. Sam |
07-29-2011 | #33 |
Don't worry Sam, we'll set ya straight....Just wait till you go to the gathering one year, that's a whole new level of crazy
07-29-2011 | #34 |
07-29-2011 | #35 |
A take-off on "all vettes are red" is what I first presumed. LOL
07-29-2011 | #36 |
07-30-2011 | #37 |
That is a smokin deal on a clean car.It surprises me how well these cars age and still look fairly clean.To the OP,the small triangle pieces missing from your seat controls can be found at Corvette Central I think.
07-30-2011 | #38 |
Sam, just one admonishment about doing a test for spark......our ignition control boxes, the DIS box mounted to the underside of the plenum, do not like for plug wires to be disconned while the motor is running. I would suggest taking the long way with an assistant and remove one wire at a time using an old spark plug start the motor & observe the spark intensity, shut down, then on to the next, etc & so on. It's not that the box is gonna puke on you when you pull wires as the motor is running but the box doesn't like for that method to be used too much. JAFWIW.
07-30-2011 | #39 |
when gordon checked my wires when I had a miss he just pulled them while the car was running.
