#31 |
![]() Join Date: Jun 2006
Power coat the topend, the clear coat paint we used is yellowing (badly in some places).
Replace the shocks, found a set of original Bilsteins with only 200 miles on them. Install the forced air intake I bought (like yours) Now the engine mounts. Thought about you yesterday, A buddy and I were checking out a 123K 91 Z for sale locally for $9995. He was thinking of getting it for his GF (he has a 94' with a Haibeck 415) Decent car, ran real good, but needed most of the usual C4 items repaired plus brakes and tires. Seller (used car dealer) wouldn't come off the price a dime. He passed. H ![]()
#32 |
Hans, an update for you... today I unbolted the lower nuts from the motor mounts, and jacked up the driver's side of the motor. I slipped 2 body/alignment shims in around the stud (I chose 1/8 inch each, for a total of 1/4 inch), and lowered the motor back down, and tightened the nuts once again. I gained approximately 3/16 to 1/4 inch of clearance between the #1 primary and the steering shaft.
I'd like to find a shim with a larger surface area, but I suppose this has got to be better than the interference that was present before.
#33 |
Update: After taking the car for a drive, the mount settled a little, leaving about 1/16" or so of clearance -- which was enough to make me notice just how much vibration was being transmitted through the car due to the interference. It's much quieter and smoother now.
#34 | |
H ![]()
#35 |
BTW Andrew... did you have to remove or at least loosen the C-Beam?
H ![]()
#36 |
When I initially did the job, yes, I removed the headers, h-pipe, and the rest of the exhaust, and removed the c-beam so that I could have as much freedom as possible to jack up the motor. When I later shimmed the driver's side mount, I did not have to re-loosen the C-beam.
#37 | |
![]() Join Date: Jul 2010
NVH=Noise Vibration Harshness peace Hog Last edited by Hog; 07-11-2011 at 08:50 AM. |
#38 | |
-Andrew
#39 | ||
A question regarding Motor Mounts came up and I refreshed an old thread with some additional information regarding Motor Mounts
![]() Oreilly Auto 2902 Summit Racing 2902 Ecklers Motor Mounts Quote:
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-16-2014 at 12:31 PM. |
#40 |
A blast from the past...
