Old 05-13-2011   #31
EvanZR1
EvanZR1's Avatar
Default Re: Finally getting my ZR-1 back from Corey's!!!
Thanks Jerry. You have to love the ZR-1 community, such a good group of guys.
EvanZR1 is offline   Reply With Quote
Old 05-13-2011   #32
You know, they really are. And trust me when I say Corey probably won't sleep tonight worrying about your car!
Old 05-14-2011   #33
Locobob
Hmmm oil getting onto headers is most likely the header stud, cam cover or possibly the cam position sensor. Ticking - likely an exhaust leak - quite possibly at the header gasket given the other symptoms. Smoke = burning oil. Rough running is likely a result of the exhaust leak throwing off the O2 sensor.
My best sight unseen guesses.
Robert
Old 05-14-2011   #34
Kevin
Kevin's Avatar
it does sound like a header stud backed itself out
Old 08-15-2011   #35
EvanZR1
EvanZR1's Avatar
Just thought I'd update this to let anyone that was interested know the answer. Turns out it was one of the "new" injectors stuck open. Swapped the originals back in, and it's running better. Will be sending the new ones back to Jon for him to check, they were rebuilt and apparently if they sit "dry" too long they can have issues.
Old 08-15-2011   #36
I had the same issue at first with one from Jon.. he will take care of you..
Old 08-15-2011   #37
Blue Flame Restorations
Originally Posted by xlr8nflorida View Post
Which Borla do you have?
To be honest, I'm not even sure. I think its the first system Borla ever had for ZR-1.
Here is a pic:
Love the yellow!!!!!!!!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 08-15-2011   #38
ittlfly
Me too!
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 08-15-2011   #39
rhipsher
rhipsher's Avatar
Hmm! My 90 makes 357rwhp with just top end porting only. And I'm still running stock cats and manifolds with a Borla. 360rwhp seems pretty week with all the work you've had done. I would think you should be higher than that.
Old 08-15-2011   #40
sammy
the lower than average figures are most likely due to corey not being ablr to put the timing in the car he would like to . nice thing about corey is he tunes the car safely so it will live. the borla is costing you at least 15 rwhp as i have tested just about all the cat back systems out there . if you removed the resonator and added a x pipe or balance tube you power woiuld get to where it should be .jmho
