05-08-2011 | #31 |
Re: Tire recommendation for all seasons?
Yeah, after an exhaustive search that is what I wanted and not available for stock size so I am going to make due with what is available. The bottom line is I need some tires now and will just use the commuter system if I have to when the cold comes around since I really don't want to drive in that type of weather. Like I said earlier and in my subject, just wanted to see if there was anything that worked decent in all seasons if need be since they don't sell specifics tires for the purpose.
05-09-2011 | #32 |
I've been caught in a TX Thunderstorm with brand new NT05's and the handling wasn't an issue nor was hydroplaning. Want me to send you some pics of the NT05's? My only caution with them is they have a lower tread wear rating and come with less tread depth to begin with as well. They will probably wear out sooner. It depends on whether you will go through the tire's life in 6 years or not. After the 6 years they should be replaced anyway.
05-09-2011 | #33 | |
