04-21-2011 | #31 | |
Re: Siamesed and dropped plenum on the bay
The block is 4.00 bore Im sure .010 to clean it up. If use your stock 350 crank (offset ground) 3.75 you would have 380ci. on the stock rods. need new pistons. use your cams,oil pump,pan,chains,front cover, damper,flywheel, chains,.... all the little bits from the 350. just a start.... or go $5k for crank and jump up to 400+ci. |
04-21-2011 | #32 |
I always thought I would eventually do one of those offset grind builds one day. They seem to be the most economical, but any rebuild is out of my reach at the moment. For now a stock 350 headers and tune is about all I can afford. It is very tempting though. The AF doesn't pay me enough to do what I want with this car yet.
04-25-2011 | #33 | |
can you please tell me why you not contact me and reply me regarding my order?? I wait your email. Long time no answer!! Give me little bit of your time.please!! Hadi |
04-25-2011 | #34 |
so is that 415 block you are throwing in good, or is it the block that was messed up during the build from BK?
04-25-2011 | #35 |
If it was me I'd be in prison for murder.
04-26-2011 | #36 |
The block is fine, there was no damage to it, it spun a bearing but didn't take out any part of the block.
05-02-2011 | #37 |
SOLD!
