12-20-2010 | #31 |
Re: Update on my hi-miler Z project
Speed Bleeders. Didn't have an issue with sealant.
12-20-2010 | #32 | |
Man alive that is a project that you're gonna be so proud of...it is a 100% transformation. My hat's off to you Andrew that car is sweet now, it's only going to become sweeter! A Q for you. How hard was the Banski kit to install? Is a lift absolutely needed? TIA Tom
12-20-2010 | #33 | |
That's good to know, that the sealant is available. I thought about teflon tape too, I wonder if that's acceptable. The Banski kit definitely doesn't require a lift to install, I don't have a lift and it went together just fine, it does require some time on your back, of course... I wish I had more pics of the car from before I messed with it, it has come a ways in the last 6 months. It's fun to compare before/after, but the pics don't really do it justice most of the time. A small sampling: |
12-20-2010 | #34 |
I did the Banski kit outside on jackstands, actually just the rear on jackstands. You will need a fairly large breaker bar to break the torque on those trailing arm bolts.
That white Z is coming along nicely |
01-26-2011 | #35 |
Update, 1 month later:
Had the motor all buttoned up, and found that my coolant outlet tubes were leaking at the gaskets (I had assembled them without sealant, obviously that didn't work). ALso had a pinhole leak in upper radiator hose. Fixed all of that, got it all back together again, cobbled together the exhaust well enough to get to a shop for welding, and fixed a persistent oil leak at the junction of the cooler and the cooler lines. I've been doing some interior work, got a new shift boot and console cover from redlinegoods.com, got the visors and trim back in place, little odds and ends. Today, I fired it up, backed out of the garage so I could do some work in the sun, seemed to run fine though had a little skip at idle after a few minutes of running. Didn't think much of it since it's been sitting. However, upon attempting a hot restart about 20 minutes later, I had to crank for 3 instances of about 5 seconds each, before it caught, and even then it was sputtering badly and barely holding an idle. Immediately, the fuel pressure regulator came to mind, since I know a hot restart failure is usually due to excess fuel in the cylinders, since I have new injectors, and the regulator was the only part of the fuel system I didn't update, naturally ol' man Murphy came knocking. I pulled the vacuum line off the regulator, and there's fuel leaking out. At least the diagnosis is made. However, now I think I have another plenum pull to do before I can get the exhaust and alignment done. Guess this serves me right for being cheap and not replacing the regulator when everything was apart. I'm starting to see a pattern developing here, and I fear that it ends with bottom end problems soon after getting this thing back on the road. Trying to stay optimistic though. |
01-29-2011 | #36 |
lot's of work, but looks like it is paying off for you. Knowledge learned the hard way is knowledge never forgotten!
02-03-2011 | #37 |
Today's update:
Got new hood hinges installed, headlights with new motor bushings reinstalled on hood. Found chewed sound deadening material in passenger footwell, looks like a mouse made a cozy little bed on the top of the hush panel. 2 wires there that need to be repaired now. |
02-03-2011 | #38 | |
Little Rat basstages
02-03-2011 | #39 |
A little late but great job! Feels great, don't it?
Makes me feel great, just looking at the pics-that's a lot of work. |
02-06-2011 | #40 |
New pics added!
Did some cosmetic work on the body today. Some light machine work with polishing compound to get some of the worked-in grime out of the paint, followed by a coat of Zaino polish. There's a lot of work still to be done on the paint, and the car really does need a repaint, but it cleaned up nicely enough to be presentable at least until I can afford a decent paint job.
Redline Shift boot and console cover: |
